flyingcow
Veteran Member
Disclaimer---I know very little about electric brakes. I have done a fair amount of wiring on my tractor trailer. Have a light tester, etc.
Bought a used GN. 22ft w/4ft beaver. The trailer brakes did not work. It's about 15yrs old and had been sitting for 5yrs. Wiring tested solid, magnets were replaced. It had the breakaway switch. But that wiring was brittle. For the sake of time, it was eliminated. But the guy working on it, wired the new battery(truck battery CCamps approx 1000, this trailer has a winch on it) directly to the "hot" wire controlling the brakes. He was told to do this? claims that the electric brakes work off of the ground side. Doesn't make sense to me, but again, i know nothing about electric brakes. Well, i've still got no brakes. towed it home 10 miles, low and behold, my brakes were slightly hot. I assume since the brakes are wired up to the battery on the trailer, it's a little stray volts doing their thing?
My pickup. Hook trailer up to pickup. Lights work, etc. But there is a weak ground. Turn signals on, clearance will do the weak signal dance too. You've all seen it. I will fix this. No biggie for me, owning and operating a big rig.
The pig tail plug on the pickup all points test good. All i have is a light tester. Put tester on brake lead, light will get brighter the harder you push on brakes pedal. release brakes in pickup, light goes out.
I know I have to get a solid ground. I plan on disconnecting the battery off of the brakes,or should I? The mechanic was told by another mechanic that this battery had to be hooked up to make trailer brakes work properly. Still, to me, doesn't make sense.
Please any help from someone thats in the know. If this thing had air brakes, I'd be allset. :thumbsup:
Also, the green light on controller does light up, blinks(ground problem), but it's on. No red light when brake pedal is pushed.
