Please, Groundbreaker X
/ Please, Groundbreaker X #1
Av8r3400
Platinum Member
North Central Wisconsin
Kubota L3400DT
Back to the original topic. /forums/images/graemlins/frown.gif
Would someone take a picture of themselves running the BX22/23 hoe or the BX2200/2230 with the Woods hoe so we can all see how the ROPS interference issue is or isn't an issue.
In specific: I would like to see a body sitting on a tractor while operating the Hoe. Also a couple of detail pics on how the 22/23 ROPS is different from the 2200/2230.
Thank you.
/ Please, Groundbreaker X #2
Here is one of My brother in-law running my BX23.
Thank you, Steve! Just what I was looking for. /forums/images/graemlins/smile.gif
/ Please, Groundbreaker X #4
Av8r
I have my hoe off but I will take some pics for you and send them to you. I've talked to a few machine shops and they can bend me a 2" x 3" ROPS for next to nothing. I have to prime and paint but no big deal. They'll also weld on light brackets front and rear for me.
I could live with the OEM ROPS on the BX2230, but I just wanted to have as much room as possible.
email your email address when you get a chance.
/ Please, Groundbreaker X #5
IMHO the OEM ROPS on the BX23 is too tall! It could be dropped up to 6" and still give adequate clearance.
Also, if I were to re-design a new & improved ROPS, I'd fabricate it to be able to fold a full 180 degrees from fully extended up too!
I have many trees & other overhangs in the front part of my property that is also very flat that precludes me from running w/the ROPS up and with it sticking straight out the back, it makes doing close in mowing in reverse very touchy as well as making sharp turns around fences & walls extremely touchy also.
Of course I've adapted & overcame these situations and continue to think that my BX23 is still THE machine for my landscapeing purposes but again, if'n I was redesigning anything on the BX23, the ROPS would be my 1st project /forums/images/graemlins/wink.gif /forums/images/graemlins/grin.gif
Keep us tuned w/this ROPS project.....
Volfandt
/ Please, Groundbreaker X #6
You want to make sure that the material that they bend the ROPS out of is of sufficient wall thickness to give you the protection that is required in a roll over. Some materials are very light and easy to bend and others are very thick and require a much more robust machine to do this. If they use thin wall (16 gauge) I wouldn't want to trust it in a roll over accident. Junk....
/ Please, Groundbreaker X #7
Heres one of me on my BX23. /forums/images/graemlins/grin.gif I'm 5'10 180.
/ Please, Groundbreaker X #8
I started to think about the hight of the ROPS on the BX22/23 and I believe that it is high like that to protect you in the event of a roll over. My quick guess is that it might have something to do with the hight of the hoe when it is fully compressed and pinned. Just a thought, but it can be confirmed by comparing the BX hoe and ROPS with some of the other Kubota hoe models and there ROPS. My bet is that there is a ratio effect that they need to maintain for safety.
/ Please, Groundbreaker X #9
I second being careful with the grade of metal they are using. A new ROPS costs about $650 at dealer cost for many machines.
/ Please, Groundbreaker X #10
The $650 is most likely OEM abuse. I talked to a few race shops that said a 2" hoop would support over 5000#. I was thinking of using tube, but it makes the canopy install harder. I have a shop looking at 2" x 3" box that is THICK stuff that they can bend to my drawings. I plan to put a hinge 3/4th of the way up so I will have protection even when its folded, but still have better clearance for trees and storage.
The height is a ratio based on the height and weight of the tractor. The BH does impact this since it add weight higher and can produce more momentum in a roll over causing the tractor to completely roll.
After talking to the metal shops, I know I can build what I want and not have to worry about safety at all. I might chrome it too. /forums/images/graemlins/smile.gif It will go with the momo steering wheel.
/ Please, Groundbreaker X #11
Chroming for looks is ok but every race sanctioning organization whose rulebook I have read specifically prohibits chroming of roll bars or roll cages because the chroming process affects the strength of the metal. While I don't think that the ROPS on a BX23 is going to be subject to the kind of abuse that a race car gives a roll cage when it crashes this is still something to bear in mind.
I don't have any pictures of myself on the tractor under the ROPS on my BX23 but the pics the other posters put up gives a pretty good representation of the operator position to ROPS height. What they don't show however is that the ROPS on the BX23 is also tall enough that you can stand up in the backhoe operators seat and still not hit your head on the ROPS. I have thought a few times myself that the ROPS is too tall - mostly because I keep thinking about adding a canopy to my tractor, and I think a canopy on the BX23 will look goofy because it will so far above the tractor. But as far as giving a nice operators station for the backhoe the BX23 ROPS is pretty good.
</font><font color="blue" class="small">( ...because the chroming process affects the strength of the metal... )</font>
Its called hydrogen embrittlement (imbrittlement?), and any chrome shop with equipment newer than the 70's doesn't really have a problem with it. If it was an issue, chrome bumpers, wheels and even the chromed hydraulic rams on your tractor would be at risk. In the application of a CUT, its a non-issue. Now if your BX was going 220 mph at Talleadega...
Go for the chrome, Matt. Make sure they put light mounts all over it too! Spot lights, floods, rotating beacon lights, the whole thing! You'll get a cover shot on "Hot Rod - Tractor" magazine or something! /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Please, Groundbreaker X #13
I guess it is unlikely to become an issue but is anyone worried about voiding the manufactures liability by modifying the ROPS? If you are under warranty I guess it is a given that you void that by changing the tractors original equipment. How it would effect a non ROPS warranty issue I don’t know. There are government standards the manufacture has to meet for roll over protection and it is one of the only things they will back once the tractor is out of warranty. I had a broken bracket on the FOPS of my B21 and Kubota replaced the part, sent a rep, took photos and sent the broken part off to be evaluated well after the warranty had expired. That told me that ROPS or FOPS failure plus liabilities were taken very seriously by Kubota.
MarkV
/ Please, Groundbreaker X #14
</font><font color="blue" class="small">( I guess it is unlikely to become an issue but is anyone worried about voiding the manufactures liability by modifying the ROPS? If you are under warranty I guess it is a given that you void that by changing the tractors original equipment. )</font>
Mark - you're mixing two different issues. First, regarding the warranty. Obviously, Kubota will not warranty a ROPS that they didn't manufacture. However, in order to void the warranty on the rest of the tractor, they would have to prove that the aftermarket ROPS caused the problem. This is a provision of the federal Magnuson-Moss Warranty Act. For example, if it's an engine or electrical problem, then it would be difficult to prove that the aftermarket ROPS was a factor. If it was a frame problem, then it could get messy. Of course, since this thread originated around the addition of an aftermarket BH, the addition of an aftermarket ROPS is a smaller step down the same road.
With regard to liability - that's a matter for a court to decide. I'm not a lawyer so I can't begin to intelligently discuss that. I will say IMO, common sense should imply that injury resulting from an aftermarket part shouldn't incur liability on Kubota's part. That also explains in part Kubota's adamant position on messing with the ROPS - all part of a legal defensive strategy.
FWIW,
Patrick
/ Please, Groundbreaker X #15
Whatever you do just don't get rid of the OEM rops, if you ever go to sell the tractor your going to need to put it back on otherwise you expose yourself to huge liability issues.
/ Please, Groundbreaker X #16
</font><font color="blue" class="small">( Whatever you do just don't get rid of the OEM rops, if you ever go to sell the tractor your going to need to put it back on otherwise you expose yourself to huge liability issues. )</font>
As a dealer, this is probably true for you. As an individual, it's not necessarily so. Again, I'm not an attorney, but individual liability and product liability are two very different issues. IMO, the manufacturer of the aftermarket ROPS would be more exposed. If this were the case, then as an individual, you'd be exposed by any minor change or even maintenance of your own tractor(there's a thread for you - don't do your own maintenance; you could get sued... /forums/images/graemlins/crazy.gif ).
There are many good reasons to put the tractor back as close to stock as possible before selling - resale value, trade-in acceptability, etc. I'm just not sure that, for an individual, liability is one of them.
Slightly OT - I remember a story several years back of a meat grinder that was sold under contract to the US military during the Korean war. Supposedly, military sales had "Hold Harmless" agreements in the contract for liability since the products necessarily are used under adverse conditions. After the war, the grinder was sold as surplus, passing thru several hands. Along the way, sheet metal guards were lost and eventually someone was injured operating the machine. The manufacturer was successfully sued by the injured party. The moral - It apparently didn't matter to the court how many intervening hands had touched this machine, they still held the manufacturer liable.
BTW, I'm not an attorney and I don't give professional advice, but I am an insurance underwriter with a general knowledge of the subject...
Patrick
/ Please, Groundbreaker X #17
</font><font color="blue" class="small">( . After the war, the grinder was sold as surplus, passing thru several hands. Along the way, sheet metal guards were lost and eventually someone was injured operating the machine. The manufacturer was successfully sued by the injured party. The moral - It apparently didn't matter to the court how many intervening hands had touched this machine, they still held the manufacturer liable.
Patrick )</font>
How can a manufacturer be held liable for a product that has been altered or safety parts removed, when it has no control over these acts? My gut feeling is that this is a Urban Legend, not a fact. I do know of a instance where a Corvair engine was modified for use in an airplane and the fuel pump also altered. When the plane crashed, the survivors sued GM and the seller of the fuel pump. After much litigation, both were cleared of wrongdoing by the courts. If it wasn't for GM being involved, then the part seller wouldn't have had the resources to fight the legal battle and might have lost as a result.
/ Please, Groundbreaker X #18
</font><font color="blue" class="small">( My gut feeling is that this is a Urban Legend, not a fact. )</font>
IIRC, it was in a WSJ article about product liability issues. Would have been about 20 years ago. It was one of a half dozen examples of product liability nightmares.
/ Please, Groundbreaker X #19
I'm 5'10" and clear fine (2"-3") Previously I posted about the distance from the seat back corner to the ROPS on the BX2230 during the installation. Look at the pics of that incredibly handsome man... I mean tractor.
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
2016 CATERPILLAR 259D SKID STEER (A64279)
2016 CATERPILLAR...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2022 Kubota MX5400HST (A64047)
2022 Kubota...
