Please critique the weld quality (photos enclosed)
   / Please critique the weld quality (photos enclosed) #61
I agree with the other threads to have the welds ground out and redone. My recommendation would be to repair with E7018 1/8 rods at 110 to 120 amps and vertical up. This rod has alloys that will not be as brittle as 6010 or 6011 though they will work fine too.
   / Please critique the weld quality (photos enclosed) #63
Our High Scool turned out many Certified Welders over the years that went directly in to the work force and are still in high demand.
Those welds must have been done by a 3rd Grader.
   / Please critique the weld quality (photos enclosed) #64
I have never welded but have done silver soldering, lead/tin soldering, and brass brazing. I agree with all the comments concerning the poor job done. The welds look exactly like solder does when a small iron is used on a big, cold piece of metal. The gaps and holes in the welds are going to hold water, and the smallest fissure over time will rust and the weld will fail. Those weld beads should be a completely solid line of metal which would look more like a an application of epoxy.
   / Please critique the weld quality (photos enclosed) #65
I won't add much to the welding conversation (other than I stick stuff together a couple of times a year, and my welds are 1000x better than this. These look like the first time i tried to use a $90 HF gasless mig).
But in your opening statement, you said that the gates were powder coated. I could be wrong, but I'm 95% sure those are not powder coated, they are spray painted (poorly). Powder coat is amazing at hiding things like grinder marks, smoothing out lumps and bumps etc.
   / Please critique the weld quality (photos enclosed) #66
Like Ovrszd, I see a battle.
Without a contract, you could reasonably expect performance (the welding job) to meet the minimum standards of the trade. In the following link, are provided the six standards of the trade, with the lowest standard being appearance.
6 Levels of Welding Quality Standards
6 Levels of Welding Quality Standards​
We received a large number of email responses and comments to our article from two weeks ago pertaining to weld ...
Present the judgements from TBN participants to support your claim that the work does not meet appearance standards of the trade.
If you decide not to pay for the job, and the vendor will not redo the job, be careful. You do not want an enforceable mechanic's lien placed on your Kinda rustic looking. I wonder if they didn't grind any paint off before they welded it.
W
   / Please critique the weld quality (photos enclosed) #67
We always called that chew gum welding. I wouldn’t trust that any further than I could throw the gate
   / Please critique the weld quality (photos enclosed) #68
I don't weld enough to call myself a welder; but mine look better than that. Mine generally hold up; but don't have a lot of stress on them. The welding on this gate might be problematic.
   / Please critique the weld quality (photos enclosed) #69
I am having fencing/gates installed. Steel material that is/was powder coated.
The photos are for hinge welds for heavy gates. 6x6 steel posts and steel gates to cover a 16 foot opening.
Before approving the job, I'd like to make sure the weld quality is sufficient for long term reliable use. Except I do not know how to evaluate the quality of a weld. Does this work look right to you?
You should have had these powder coated after the hinges were welded on....or ground the powder coat off before welding the hinges on. The welder should have known to grind that crap off though
   / Please critique the weld quality (photos enclosed) #70
As a Welding Inspector for over 40 years, these are some of the worst I have seen. Lack of heat, done in windy conditions (porosity) and over-all Garbage. Amateur trying to weld vertical. Remove all of it.
2025 SDLANCH SDLE18P UNUSED Mini Excavator (A53117)
2025 SDLANCH...
2025 IR IRMC 8D UNUSED Massage Chair (A53117)
2025 IR IRMC 8D...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
2014 TROXELL 130 BBL VACUUM TANK (A53843)
2014 TROXELL 130...
2025 K2223 UNUSED Double Garage Metal Shed (A53117)
2025 K2223 UNUSED...
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
