Please critique the weld quality (photos enclosed)
   / Please critique the weld quality (photos enclosed) #21
I'll pile on! Those are awful, amateur welds. I see lack of fusion in a couple pics for sure as the toes are just beaded up sitting on top of the metal. So if the hinges are this bad, what about the rest of the welding? They might have glopped on enough metal to be able to grind back flush but it is doubtful that other welds are properly fused either, unless done by different people.
   / Please critique the weld quality (photos enclosed) #23
I definitely agree with all the comments. Very poor, non- professional welds. Potentially lethal if they fail.
You might call the local Boilermakers union hall and see if they can recommend a welding inspector to provide a professional opinion to back up any legal action you might consider.
   / Please critique the weld quality (photos enclosed) #24
Just terrible
   / Please critique the weld quality (photos enclosed) #25
Ugly. I am an AMATURE welder. These look bad even to me! The company owner should take one look and call for a do - over.
   / Please critique the weld quality (photos enclosed) #27
I am having fencing/gates installed. Steel material that is/was powder coated.
The photos are for hinge welds for heavy gates. 6x6 steel posts and steel gates to cover a 16 foot opening.
plowhog,
If you really want better advice on weld quality, you should post your photos and questions on the following welding dedicated sites. Not knocking TBN's contributors, but we are really a bunch of tractor/ equipment guys who occasionally have to fix some stuff we broke. ;)
A professional welding site run by a master welder with decades of experience.
A sister site ( if memory is correct ) to TBN
   / Please critique the weld quality (photos enclosed) #28
plowhog,
you don't need to be a ''expert'' to know this weld is crap and wouldn't handle any stress ...
   / Please critique the weld quality (photos enclosed) #29
Those are not welds. That is cold mettle somewhat stuck to some other mettle. Don't worry though, it will not be stuck there long.
That is about the worst welding I have ever seen that was not an on purpose joke.
They are charging you for that!!!??? If an actual trade welder was nearby when they did this, there would be a welding rod stuck up someone's rear end!
   / Please critique the weld quality (photos enclosed) #30
We call guys making these kind of ''weld'' grinders and not welders ...
   / Please critique the weld quality (photos enclosed) #31
plowhog,
I am a NDE Level III (Non Destructive Examiner) (Level III means I am at the highest achievable level in this field) with 29 years experience in the nuclear industry. I currently am the program owner and level III in a USA nuclear power plant. I think I can speak to those welds as good as anyone alive. I do not even need my Ultrasonic flaw detector to interrogate these welds :) .
Pure trash.
Farm welds are typically no where near that bad. That said, I have seen some pretty crappy welds hold up to amazing abuse. I would have a real hard time paying for that bad of a job. If it was me doing the welding and that was the best I could muster from my $79 HF flux core MIG welder.... I guess that I would have to accept it. But paying for that would hurt a lot.
   / Please critique the weld quality (photos enclosed) #32
I like the Grease Zert for the Pins ! As a Novice at welding . I'm see no prep at all ... No touchup paint, No wire brush or disc marks . He burned through the paint and his wire feed was to low .
   / Please critique the weld quality (photos enclosed) #33
Before approving the job, I'd like to make sure the weld quality is sufficient for long term reliable use. Except I do not know how to evaluate the quality of a weld. Does this work look right to you?
The fact that they tried grinding some of them just to get them to look okay says a lot...
I'm not trained but when my welds look like that I cut them off and try again and that's just for me let alone when I do it for someone else.
   / Please critique the weld quality (photos enclosed) #34
I wouldn't call those things a weld for starters. More like hemorrhoids.
The thing is....a good weld would have been MUCH easier to do than those goobers he put on.
   / Please critique the weld quality (photos enclosed) #35
   / Please critique the weld quality (photos enclosed) #37
Today with contractors not being able to find qualified people to hire, this is not in the slightest bit surprising. Why do a job that requires working outside in the elements when you can earn a good living setting behind a computer and create a virtual solution to a virtual problem. Expect work like this to be on the rise.
   / Please critique the weld quality (photos enclosed) #38
I am a certified welding inspector/examiner and I also have my own company doing welding, training and procedure consulting along with custom welding and fabrication. I will tell you that it looks like the hinges were welded in the field after the main parts were fabricated and painted. You can tell the welds were cleaned and painted in place which is common, but they used a mig process with not enough heat or penetration. I would not accept these welds for the simple fact that they will not hold over time. The welds will fail causing gate to fall and possible damage or personal injury could happen which makes it a safety issue. I would think if you called a supervisor or manager and politely explained your concern that they would make an effort to fix. Also, if they charged you for powder coating, I would address that too because powder coating can not be "touched up" after welding. So just be sure exactly what you are paying for. Remember, you are the customer paying for a product or service and should be getting quality work. You could also mention hiring a certified welder to fix welds and they should pay for that service.
Can you show us a few examples of the gate construction welds. Are they the same or better quality?
The gate construction welds are visibly different. To me, they look smooth and professional. The owner said he will redo all the hinge welds. The person who did the gate welds will redo the hinge welds.
   / Please critique the weld quality (photos enclosed) #40
(y)
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
Kubota Snow plow with subframe
Kubota Snow plow...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
2014 Nissan Altima Sedan (A59231)
2014 Nissan Altima...
2372 (A60432)
2372 (A60432)
2020 Ford Ecosport 4WD SUV (A59231)
2020 Ford Ecosport...
