Plastic replacement fuel tank for JD 1020 ?
   / Plastic replacement fuel tank for JD 1020 ? #1
Figato
My JD 1020 (diesel) has a leaky fuel tank.
Not sure where the leak is coming from. I'd have to pull the tank to find it.
Being that the problem part is just a TANK, my thought is that I'd be better off replacing it with a new plastic tank.
At least in the short term, I could get it up and running, then later go back and replace the stock tank if I choose to do so...
Problem is that I cannot find anyone who makes a drop-in replacement tank. I thought this would have been an easy find.
Seems like a common problem and someone would have come up with a "universal tank" or something.
Anyway...
Looking for suggestions -
Anyone know of such a product?
Can someone recommend an alternative - like a tank for a riding mower?
Any drawbacks to doing this?
THANKS IN ADVANCE!
   / Plastic replacement fuel tank for JD 1020 ? #2
There is a plastic gas/diesel fuel tank repair kit. It sells at most auto stores. It is like JB Weld for tanks.
   / Plastic replacement fuel tank for JD 1020 ? #3
I stuck a piece of 1/2in rebar thru the bottom of my tn75 fuel tank. New cost was over $400. I decided to try plastic welding. I went to the scrap yard and got a piece of plastic out of a car fuel tank to use as filler. I took my pencil type soldering iron and turned the flat point up on edge and started going around the hole in the tank until the plastic started getting sticky melted. I then used the filler material and used the hot solder iron to push it into the plastic around the hole in the tank. The plastic welding process was a lot easier than I expected it to be and the fix held for 2 years until I sold the tractor. Far as i know, its still holding. The key to plastic welding is to use the same material for a filler as the object being welded, and not completely melt the piece that is being welded.
Plumber supplies also sell a abs plastic cement that will work on most plastics. Just be sure you get the cement and not one of the abs glues.
UNUSED AGT MXCRT23 STAND ON SKID STEER (A51247)
UNUSED AGT MXCRT23...
(12) ROLLS OF WELDING WIRE (A51247)
(12) ROLLS OF...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53472)
2019 Krause...
2021 JOHN DEERE 8R250 LOT IDENTIFIER 179 (A53084)
2021 JOHN DEERE...
1999 CHEVROLET C7500 UTILITY TRUCK (A53426)
1999 CHEVROLET...
