Plastic repair on Kubota BX
   / Plastic repair on Kubota BX #11
You might check with guys who repair plastic auto bumpers. Some of them can be heat welded with a plastic welder. Some can be glued back together. Then there are some that I dunno if anybody could fix.
As 2 Many said I've found the welding just a matter of finding out what the plastic material is. Kubota in thier response to d1king said "just go out and buy another fender!!!" My response to Kubota is FU!!
Every replacement part on that BX2350 would call for refinancing your home. I like the tractor but Kubota's attitude has been bad as far as I'm concerned. I had a problem with the valve manifold leaking when the tractor was brand new.
My tractor was out of service for TWO MONTHS due to some improperly sized flares on some SS tubing.
My dealer (who was really great by the way) found out that Kubota knew that they had this "little" problem with the flaring on the tubing but had failed to tell the dealers. After the dealer discovered the problem it took 6 WEEKS to get tubing with the proper flare from Kubota. Now that's real customer service!!!!
Paul
   / Plastic repair on Kubota BX #13
I am one of those guys, but I need more info, before I can be of any help.
   / Plastic repair on Kubota BX #14
Santacruzer, My thoughts exactly on buying something to help their bottom line, but then the alternator seized up. I was going to get one thru internet (ebay) then found out my stepson had gotten one from Kubota dealer at $240.00 trying to be helpful. He and tractor are 220 miles away, kind of slows me down. I'm going to try different epoxies on the underside of the fender to find out what will hold. Don
   / Plastic repair on Kubota BX #15
More likely than not, there will be a recycling code (the little triangle thing with a number in it) on the back of the panel. That will tell you what type of plastic it is. Then a plastic shop or ray66v could tell you the best way to fix it.
   / Plastic repair on Kubota BX #16
There is. IIRC it is an ABS/something mix. I had a post somewhere about my BX plastic fix*..may not have updated it but I ended up welding it from the backside with an el cheapo Harbor Freight plastic hot air welder using the ABS rods. Do it from the back cause it looks like crap, at least my plastic welds did;)
*found it PC+PBT+ABS mix
All you guys are great!! Thanks for your time and concern...that's what makes this such a great web site!!!
Paul
   / Plastic repair on Kubota BX #18
What I've used on motorcycle fairings (an ABS blend) is Devcon Plastic Welder available at Walmart. It's a two part epoxy with some kind of smelly solvent (acetone?) in it to soften the base plastic as the epoxy cures. Use some aluminum gutter flashing as a back-up plate.
   / Plastic repair on Kubota BX #19
Skyco, I'd like to hear more about plastic welding! Wife just bought one for my birthday. Have you welded other things with it? Any tips. Richard
   / Plastic repair on Kubota BX #20
ABS pipe cement is the best thing I've found, just be careful with it, it's black.
Reinforce the back side with fiberglass cloth covered in the ABS cement.
Let it dry overnight before using the part.
DO NOT USE PVC cement.
This repair will only work if you haven't used any other glue already.
Traffic Cones (A44502)
2006 JLG 600AJ 4X4 ARTICULATING BOOM LIFT (A45046)
2006 JLG 600AJ 4X4...
15 YARD HOOK LIFT ROLL OFF CONTAINER (A45046)
15 YARD HOOK LIFT...
2010 TEXMEX CONTAINMENT TRAILER (A45046)
2010 TEXMEX...
2017 John Deere 652R 52in Stand-On Mower (A42744)
2017 John Deere...
John Deere 5410 Tractor (A44391)
John Deere 5410...
