Plastic plumbing or copper, whats do you prefer ?
   / Plastic plumbing or copper, whats do you prefer ? #21
Building new home now and it will be PEX! Can highly recommended AND preferred by the plumber doing the install.
Michael
   / Plastic plumbing or copper, whats do you prefer ? #22
Here is some info posted in a totally unrelated forum regarding PEX connectors:
QUOTE
found PEX connectors today that are the greatest thing since sliced bread IMO. They are called SharkBite, and are made by Cash Acme. You can see them at this URL:
Cash Acme - Products - SharkBite® Connection System
The connectors fit PEX, Copper and CPVC (all have the same OD). I found them at Home Depot in the copper fittings plumbing section. They just slide on the pipe to make a leak proof connection. They can be removed at any time using a "disconnecting clip" to depress the release collar (clip costs a buck or so). They also swivel, which is important if you are using a 90 degree elbow connector or otherwise need to turn one side or the other of the pipe. Cost was about $5.30 each for straight connector, and about $5.85 for 90 degree connector. Home Depot also sells PEX in 5 footsticks (about $1.75 for 1/2 inch ID - 5/8 OD).
UNQUOTE
2016 Ford Fusion S Sedan (A53424)
2016 Ford Fusion S...
ST205/75R15 Trailer Tires (A55787)
ST205/75R15...
UNUSED SDLANCH SDLC2030FT ALL STEEL CARPORT (A54757)
UNUSED SDLANCH...
200722 (A51247)
200722 (A51247)
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
Freightliner Tender Truck - Adams Tender (A55301)
Freightliner...
