Plastic liner in snowblower impeller housing
   / Plastic liner in snowblower impeller housing #1
Mercmaniac
Montrose, PA
John Deere 2520 & John Deere 445
I have been thinking about lining the impeller housing of my new 54" snowblower with 1/8" Delrin (McMaster-Carr). I would use 10-32 SS countersunkhead screws with nylon locknuts. I want to use machine screws so that changing the liner out down the road due to wear will be easier. I have been running a 47" blower on my 445 for about 15 years. It has been an awesome setup but stones and gravel have really worn the inside of the impeller housing. I had to have a patch welded on it near the bottom 2 years ago due to a open slit that developed.
Anyone here have any experience doing this? Any further suggestions would be greatly appreciated.
Love this site and the wealth of info given out here!!!
   / Plastic liner in snowblower impeller housing #2
This gave me an idea. I wonder how effective a coat of spray on RUST-OLEUM rubberized undercoating would be? I may give this a try myself.
   / Plastic liner in snowblower impeller housing #3
i tried that last winter with my 64" Ber Vac blower. it worked for a while but ended up being more trouble than it was worth and I took it out.
A better solution is this. SNOWBLOWER IMPELLER KIT works like a charm even on the bigger 3pt. blowers.
scesnik, what problems did you encounter? The impeller kit is for performance increase. I am looking for something sacrificial to keep the housing from being worn. Even if I had to replace it each year it would be worth it to me if it saved the housing.
   / Plastic liner in snowblower impeller housing #5
It just wore out rather quickly. Especilly where the countersunk screws were. Then, once it wore there it didn't take long for it to be useless. I think a piece of sheet metal spot welded in place would work better.
   / Plastic liner in snowblower impeller housing #6
I would clean the area and spray with bedliner I use it for lots of things including blower chute works well and easy to touch up
   / Plastic liner in snowblower impeller housing #7
I had a farmking 60" 3 point blower that i ran for about 8 very hard winters and i did get some compaction problems in the chute but this only happened if i shut off the pto or pressed in the 2 stage clutch all the way BEFORE i cleared all the snow from the impellers. If i let it blow itself out there was never an issue.
As to the wear and tear, i did have to repaint the interior of my chute every year, as the snow does a number to it. I really don't know how the plastic liner will work. I added plastic runners to my horse drawn sleigh a few years back, and they really do get scuffed up alot. I was amazed how rough they become after time.
   / Plastic liner in snowblower impeller housing #8
I have a gravel drive and faced the same problem. I had a metal fabricating company roll a 3/32 inch iron ring (about 4 inches wide) to the right diameter and welded it inside the drum . Problem solved.
   / Plastic liner in snowblower impeller housing #9
Thanks for the link. Nice to see a local doing something different. :)
   / Plastic liner in snowblower impeller housing #10
I took different approach
Used a child's sled FLYING CARPET (Google)
to line chute with Held in with pop rivets and aluminum edge guards
secondary gain when it does plug much easier to clean
11ft S/A Fuel Tank Trailer Frame (A51691)
11ft S/A Fuel Tank...
2015 ISUZU NPR 16FT BOX TRUCK (A54313)
2015 ISUZU NPR...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
2016 Ford Fusion S Sedan (A53424)
2016 Ford Fusion S...
Electric Mobility Scooter (A51694)
Electric Mobility...
2015 INTERNATIONAL DURASTAR 4400 WATER TRUCK (A53843)
2015 INTERNATIONAL...
