Plastic Fuel Filter Assembly Question ???
/ Plastic Fuel Filter Assembly Question ??? #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
I have a new to me Kubota M5640. It has a new to me all plastic sediment bowl/fuel filter assembly. I wanted to clean it. When I unscrewed and dropped the sediment bowl I expected the filter element to stay on the tractor but instead the bowl and filter all came out as one piece. Seemed odd to me but I don't know maybe that is normal. Anyway, when I tried to remove the filter cartridge assembly from the bowl by prying on it it wouldn't come. I couldn't wiggle it at all. I put as much pressure as I dared on a plastic piece that I wasn't sure about. So, Is there a trick to pulling the filter element out of the bowl or was I just to gentle ????? Thank you.
gg
/ Plastic Fuel Filter Assembly Question ??? #2
Get something and hook one of the slots around the edge and pull straight out, and do not loose the 2 O rings.
David
OK thanks. Looking at it I wasn't sure it came apart.
gg
White Oak Boards (A65640)
White Oak Boards...
2024 JCB 35Z-1 EXCAVATOR (A65053)
2024 JCB 35Z-1...
2006 STERLING ACTERRA CAB & CHASSIS (A60736)
2006 STERLING...
2015 Nissan Leaf Hatchback (A64557)
2015 Nissan Leaf...
2012 Peterbilt 367 Sleeper Truck, VIN # 1XPTD40X5CD149943 (A65563)
2012 Peterbilt 367...
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
