Plastic blades on air filters
   / Plastic blades on air filters #2
Not sure as to the exact reason but most all diesel engines have seemed to have them. They most likely cause the air to rotate dropping out the large particles like a vacuum cleaner
   / Plastic blades on air filters #3
You are correct , the fins cause a vortex action created by the incoming air which throws heavier particles outwards which are collected and dispensed via the rubber reed valve at the bottom of the air cleaner housing . It also helps elliminate punctures of the paper element by sharp objects such as grass seeds etc by the same action .
   / Plastic blades on air filters #4
I always thought that when the air was being sucked in they would turn and act like a "turbo".. But I guess that isn"t right either!!!! Because when I installed it yesterday I tightened the screw up against the filter,, therefore no spinning!!!!!! All I know is that it went into the cannister,, and fit......
23013 (A53421)
23013 (A53421)
Flat bed trailer (A52377)
Flat bed trailer...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
CRAFTSMAN ZERO TURN MOWER (A53843)
CRAFTSMAN ZERO...
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
2022 CATERPILLAR 303.5 CR EXCAVATOR (A52705)
2022 CATERPILLAR...
