Plastic blades on air filters
   / Plastic blades on air filters #2
Not sure as to the exact reason but most all diesel engines have seemed to have them. They most likely cause the air to rotate dropping out the large particles like a vacuum cleaner
   / Plastic blades on air filters #3
You are correct , the fins cause a vortex action created by the incoming air which throws heavier particles outwards which are collected and dispensed via the rubber reed valve at the bottom of the air cleaner housing . It also helps elliminate punctures of the paper element by sharp objects such as grass seeds etc by the same action .
   / Plastic blades on air filters #4
I always thought that when the air was being sucked in they would turn and act like a "turbo".. But I guess that isn"t right either!!!! Because when I installed it yesterday I tightened the screw up against the filter,, therefore no spinning!!!!!! All I know is that it went into the cannister,, and fit......
2017 FREIGHTLINER M2106 TELESCOPIC BUCKET TRUCK (A51406)
2017 FREIGHTLINER...
UNUSED AGT YSRT14 STAND-ON SKID STEER (A52706)
UNUSED AGT YSRT14...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
2015 Ford Focus (A51694)
2015 Ford Focus...
