Plasma cutter recommendations
/ Plasma cutter recommendations #81
I was just reading a thread over on Welding Web that included inexpensive plasma cutters. 'Brand X' says he has bought and compared several plasma cutters over the years and now the market has matured. He found a couple around $100 that are surprisingly good, can cut 1 inch plate.
He started this long, rambling thread to compare cheap stick welders. But his occasional mentions of plasma cutters is worth plowing through all that, to learn what he knows, based on his long experience with pro gear and now cheap stuff that seems to work just as well.
A quote from another of his posts
I really think the little 120 volt plasma is my favorite low dollar unit. The IGBT models have come a long way in improving on the blow up factor of the Mos-Fet units. Even the consumable life is improved a bunch.. $9 worth of cheap consumables goes a long way.. I pushed this thing trying to blow it up, and it just runs cool, and cuts well.. Tried a test on some older Ebay units, and had no issue blowing 3 of them right up.
You may have to search on his name in each page of the thread to skip over a ton of unrelated stuff.
/ Plasma cutter recommendations #82
I've been looking for something like this. It was worth plowing through his rambling - gave me a lot of useful advice. Thanks for mentioning, sir!
/ Plasma cutter recommendations #83
Whatever plasma cutter you get, try, I mean really try to get one that uses Hypertherm consumables because
1) Hypertherm consumables tend to work well if not better than others.
2) Hypertherm consumables are ubiquitously available everywhere, including in your father's sock drawer.
3) and finally because Hypertherm consumables tend to be less expensive than other brands.
/ Plasma cutter recommendations #84
Don't forget the proliferation of Hypertherm consumable knockoffs.
Incredible (cosmetic) quality, identical packaging. I dare you to tell the difference.
/ Plasma cutter recommendations #85
Had the Hypertherm 30Air for a few years now and it's been very handy. I'm a hobbyist with minimal equipment - Millermatic 175, the Hypertherm and more recently an Everlast inverter stick machine. Really happy with all of them. The Hypertherm and the Everlast can be run on either 120 or 240V. That makes them handy to use offsite, although the 120V capabilities are more limited.
/ Plasma cutter recommendations #86
I think there are even knock offs of Knock offs butchered a couple cuts today, working on my QA conversion- thought the china cutter finally bit the dust.
But it was defective new consumables. Literally had just put in new ones and they were defective would not cut for anything just half gouging Really thought the cutter was dying, tried a different new set from another china consumable supplier i had in a different box and a great cut. Sure made a mess before I figured it out though.
Future note to self- always do a test cut before cutting the real piece.
/ Plasma cutter recommendations #87
I have no other experience for comparison but I have been very satisfied with my Hypertherm
/ Plasma cutter recommendations #88
I had and sold a Hobart machine a few years ago and replaced it with a Hypertherm. Very satisfied with it, especially the fine cut consumables. Use mine for cutting and gouging welds.
/ Plasma cutter recommendations #89
I recently bought a Primeweld Cut60. It's amazing to be able to cut through sheet stock like butter. But I find it tricky to make precise cuts and so I'm still cutting tubing and bar stock with my bandsaw. If someone is pretty much cutting tubing and bar stock, I'm not so sure whether the money might be better spent on a cold saw like one of the Evolution saws?
/ Plasma cutter recommendations #90
For bar stock and structural I've always used my horizontal band saw. I agree, a plasma cutter is ill suited for those operations. The 'cold saws' are pretty expensive compared to a horizontal band saw IMO. I use my Hypertherm mostly for gouging off welds. As good as air-arc gouging, less messy too.
/ Plasma cutter recommendations #91
I see what you are saying. Cold cut saw blades do get pricey relative to the number of cuts before they have to be replaced.
/ Plasma cutter recommendations #92
For thin gage sheet metal like steel barn siding or light gage aluminum sheet, I take a carbide tipped wood saw blade and install it backwards on my DeWalt corded circular saw and cut it with that. Considered one of those Milwaukee metal cutting circular saws but my DeWalt with a reversed wood blade (carbide tipped), works just as well. You just have to be wearing PPE as in safety glasses and a long sleeve shirt as the chips produced are hot and they fly everywhere.
/ Plasma cutter recommendations #94
Plasma shines in a bunch of ways but priceless cutting rebar, Tposts, bed frames and cutting edges. My band saw and cold saw don't like that stuff. Gouging and beveling are great as well.
Free hand notching and saddles work well with practice and practice is key to all of it.
/ Plasma cutter recommendations #95
I have a 20+ year old Hypertherm 900 originally I used it on a cnc table but mainly now handheld cutting. Will pierce 1” and cut 1-1/4. Parts and consumables still available. Biggest thing is clean and DRY air, being I live in a place where 70-80 percent humidity is not uncommon that was my biggest learning curve. To me the most important thing is to stay with a company with long term parts availability. My welders are Miller,Hobart Lincoln with Hypertherm cutter.
/ Plasma cutter recommendations #96
Is it a Powermax 900? The 900 was only rated for 7/8, I know it can sever more but 1.25 would be pushing it, and piercing 1in would be pretty destructive on consumables!
I run a 200amp Maxpro at work and I have to edge start on anything over 1.25in
I had a PM105 and now a PM85 on my personal table, they are awesome machines. I'm pushing to get a HD plasma at work or maybe even a laser!
Sent from my SM-G715U1 using TractorByNet mobile app
/ Plasma cutter recommendations #97
I own a Hobart 40i it's 40 amp 220 only and you need to plug it into an airline. No problems ever and a Great machine for the last 5 years it will sever cut over 3/4". The newer
One that replaced it is multivolt 120 or 220 I'm pretty sure it's not a standalone meaning it doesn't have a built in air compressor however the smaller ones do.
/ Plasma cutter recommendations #98
After owning/operating my Hypertherm 45xp for several years, I can honestly say I spent more money than I am getting in return for it. It is a dream machine for me and I smile every time I use it. But the problem is I am not using it as much as I hoped.
When I retire and have more time, hopefully I will rectify that. For those that think you will seldom use your PC, a cheaper one might be smarter and will allow purchase of other less frequent use type tools.
No regrets... just food for thought if your budget is tight.
/ Plasma cutter recommendations #99
I also bought a primeweld 60. Use it here at the farm. I've been pleased . Didn't want to spend a lot of $$ for something I wasn't going to use daily. It works for me
/ Plasma cutter recommendations #100
Stay tuned for the new "Hatchet 60" release. Compact, powerful and will cut the legs out from under a Primeweld 60.
(INOP) 2022 MACK MD6 WATER TRUCK (A64280)
(INOP) 2022 MACK...
2003 CASE 590 SUPER M SERIES 2 BACKHOE (A65053)
2003 CASE 590...
2018 CATERPILLAR 320 EXCAVATOR (A65053)
2018 CATERPILLAR...
84in Hydraulic Dual Cylinder Grapple Bucket Skid Steer Attachment (A64553)
84in Hydraulic...
TAG 48" QUICK ATTACH EXCAVATOR BUCKET (A65053)
TAG 48" QUICK...
2019 Cub Cadet Ultima ZT 1 50in Zero Turn Mower. (A64553)
2019 Cub Cadet...
