Planting corn with the JD 71
   / Planting corn with the JD 71 #1
Oleozz
Pa.
International 1066 with Year Round Cab, Kioti DK 45S with Cab, 451 Loader
I bought the 71 last spring and it's in good shape, it's missing a fertilizer box but thanks to Farmwithjunk I now have a parts manual and know what to order.
One of the things I've learned about using the 71 is seed bed prep is critical. It's a great planter and does what it's supposed to do but sometimes its owner is lacking in the necessary skills to make it perform the way it should, but each year things get a bit easier.
   / Planting corn with the JD 71 #2
I have never seen a 71 planter with fertilizer boxes. I have one and that is the major drawback I see with these planters. If you get yours retrofitted with fertilizer boxes, please post pics and information about costs, ease (or lack thereof) of attaching them etc., in other words, all the particulars. I would like to have fertilizer boxes on mine as well.
By the way, I envy you guys with cabs in this hot weather. When the weather is nice, I'd just as soon be out in it, but in the heat give me some good AC.
   / Planting corn with the JD 71 #3
Lookin' good! For some reason, most of the original end users of #71's didn't use integral fertilizer attachments, choosing to broadcast fertilizer before planting and side dress post- emerge. (Including me...) I've only seen a couple planters with dry fertilizer units. You MIGHT find a fert. box for a #25 Deere unit planter in a salvage yard, but they're scarce too. #25's were vaguely simular. Yetter doesn't offer fertilizer attachments for their rendition of the 71 either.
   / Planting corn with the JD 71 #4
Farmwithjunk said:
Lookin' good! For some reason, most of the original end users of #71's didn't use integral fertilizer attachments, choosing to broadcast fertilizer before planting and side dress post- emerge. (Including me...) I've only seen a couple planters with dry fertilizer units. You MIGHT find a fert. box for a #25 Deere unit planter in a salvage yard, but they're scarce too. #25's were vaguely simular. Yetter doesn't offer fertilizer attachments for their rendition of the 71 either.[/QUOTE
Farmwithjunk: What attachment do you use to side dress post emerge? Do you use dry or wet fertilizer?
   / Planting corn with the JD 71 #5
Don't have it anymore since I'm not growing corn any longer(other than sweet corn in the garden) but I did have a Deere RG4 cultivator with Gandy side-dressers mounted on it. I'd plow down N, broadcast multi-purpose fert, then usually side dress with Ammonium Nitrate once crop was several inches tall. Maybe not the best way every year, but I had good results most years.
Last couple years I did a corn crop I tried liquid N. I used a John Blue applicator that was rented from our co-op. So-so results in a bad growing year both times.
I was at a friends house last night looking at his older JD tractors, one was a 630 and the other I believe was a 520, he said both 2 cylinders but he had a two row JD planter sitting behind his 630. It had two fertilizer boxes exactly like I need and also had a herbicide and a pesticide box behind the corn bins. I forget the model but some nite when he's sound asleep I'll slip down to his farm and.............!!
   / Planting corn with the JD 71 #7
Oleozz,
That sure is a pretty Setter in your avatar!!
I never let a Setter pic slip by..... And, my name does not refer to the beverage!
   / Planting corn with the JD 71 #8
FarmwithJunk,
When you used liquid N, did you plow it in, put it on pre-emergent or after thr corn was up and growing? I grow sweet corn and a little field corn and need to add some N. The corn is up (about 10" high) and I am wondering if applying liquid N now would burn the corn.
Thanks,
Dave
   / Planting corn with the JD 71 #9
Dascro said:
FarmwithJunk,
Thanks,
Dave
I knifed it in. 10" corn would be a little risky. I'd suggest side dressing with a general purpose fert, maybe one with a higher N count and keep it a few inches from the plant.
   / Planting corn with the JD 71 #10
Oleozz....Not sure but I don't think those fertilizer boxes would fit on your 71. I'd hate for you to get a rear end full of buckshot trying to "borrow" them late one night. Better make sure before you do something drastic.
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
2025 72in Rock Bucket Skid Steer Attachment (A50322)
2025 72in Rock...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
Forklift Attachment for Petty Boom (A47384)
Forklift...
2012 Volvo XC70 Wagon Sedan (A50324)
2012 Volvo XC70...
