Planters
/ Planters #1
Fishincoach
John Deer 850
Will a John Deere Flex 71 do a good job planting Sorghum and Millet? How about a Cole or Covington?
/ Planters #2
New Covington with approx 30 different plates available would probably be the choice for me. Ken Sweet
/ Planters #3
You would likely get more responses on the attachment forum.
I have a 71 planter but have only planted corn, beans and pumpkins/squash with it. There is a whole page in the 71 manual on setting up the 71 for sorghum. My manual makes no mention of millet.
/ Planters #4
They'll do the sorghum OK. Millet is such a small seed, it needs to be drilled. You can broadcast it, and disc it in lightly. Mark
/ Planters #5
you could contact these guys and see if there is a plate or one that can be made for Millet. Don't know anything about them but found them before while looking for a source for new plates.
Lincoln Ag Products
/ Planters
Thanks guys, I ended up finding two of the older double hopper Cole planters and a Pittsburgh cultivator. One is in really good shape with the other a little stiff. As of now I can only work one row at a time because the max wheel base on my tractor is only 52". The planters came with lots of corn plates, and some peanut plates. I worked with Holder and Sons in NC and bought all the gears to change spacing plus a Sorghum plate and a Cantaloupe plate. Online I also found the charts for seed plates and seed spacing with the different gears. I am going to try the Sorghum plate on the smaller Millet seed and see if it does good enough, if not I will broadcast and disc in.
I am not in a hurry but looking for a slightly larger tractor that can work two rows, I will most likely not plant but 5 to 8 acres this year so I should be ok with my one row set up.
/ Planters #7
I have a old cole 700 line double hopper planter need to know where I can get plate charts .:tractor:
/ Planters
I found the charts online somewhere doing a search. I will try to attach copies here.
  • Cole Planter Plates (1).pdf
  • Spacing Chart.pdf
/ Planters #10
Fishincoach the copies you sent are just like what I can make out inside the hopper lid thank's...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
STIHL HT131 POLE SAW (A62613)
STIHL HT131 POLE...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
Lockers (A62613)
Lockers (A62613)
3142 (A63117)
3142 (A63117)
Kuhn FC400RG (A60462)
