Plans (drawing) for 425 Quick Attach plate?
   / Plans (drawing) for 425 Quick Attach plate? #21
They are not that hard to make. Before I had a welder, I had Lackender make up some for Carl and I. I just gave him the dimensions. I believe the price was $100 or less but these are thicker metal than the smaller gas models. If you have a welder, they really are a fairly simple design.
Ken
   / Plans (drawing) for 425 Quick Attach plate? #22
If I was going to make one.... I'd make 3-4 or even 6. Unless you have a good source of scrap metal (which is getting harder and harder to find) new materials will cost you. If you figure in custom welding/fabrication shop labor, you're looking at over a hundred bucks pretty quick just in a couple hours labor.
   / Plans (drawing) for 425 Quick Attach plate? #23
Yes, the first one is more expensive labor wise. Multiples drops the cost per plate. I had 6 made for me, I forget how many for Carl.
Ken
   / Plans (drawing) for 425 Quick Attach plate? #24
6 for me as well and I have only one left and three I might need. Gonna have to figure that out shortly. I think it was 75 apiece then. But jeez that was 6 years ago or more.
   / Plans (drawing) for 425 Quick Attach plate? #25
I just had one made this past summer and it cost me $90. Mistake I made though was having it welded onto a bucket too low and now at full curl I barely hold materials in the bucket.
   / Plans (drawing) for 425 Quick Attach plate? #26
Yeah. Ken can comment on this but remember a weld direct might not give you the best angle on the implement
   / Plans (drawing) for 425 Quick Attach plate? #27
Yes, I have needed to tilt out the bottom of the attachment plate when welding it to an implement. It is not the height on the bucket but the tilt of the plate. The PT has a strange range of tilt - The PT can tilt the plate to rest flat on the ground but not much past vertical.
Ken
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58216)
2023 WRANGLER...
Suzuki Vision Quad Runner 500 (A55272)
Suzuki Vision Quad...
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
LOT: Receiver Hitches, 1/2 Ton Sheet Clamp, Pipe Threader (A59076)
LOT: Receiver...
UNUSED SDLANCH 20'X20' STEEL CARPORT (A58376)
UNUSED SDLANCH...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
