plane leveler
/ plane leveler #1
Aubrey foster
1987 John Deere 750
Not sure of the correct name of this attachment but it's made with 2 -48" x12" side rails. It has two angles that weld to bottom that are caddy corered from each other and then it has the 3 point attachment welded on the top side of the beams. The two angles that are welded on bottom has blades mounted on them to cut My question is does anyone know how much of the blade should be below the main frame. Thanks
/ plane leveler
This is what I made.
/ plane leveler #3
Might make it adjustable, and then pick the height by trial and error.
Took me a bit to decipher the "caddy corered" but kitty cornered is what I came up with. I can only see one angled blade. Is there another to be added?
/ plane leveler
Yes their is two blades
/ plane leveler #5
You might find out that the lower 3 point connections are located too high. I did that with mine and it wanted to tip forward even though it weighs 700 lbs.
Other than that it looks good.
/ plane leveler
Thanks for all the info
/ plane leveler #7
I wish I could weld like Aubrey foster.
/ plane leveler #8
I like your grader - nice job. I think you will like it very much.
I put my blades down 3/4" which works fine for me. Wish they were adjustable though, because they wear.
/ plane leveler #9
Gordon Gould, Thats a great looking grader.
Army Grunt
Case 1020 25ft Draper Head (A63118)
Case 1020 25ft...
2010 Massey Ferguson 2625 (A60462)
2010 Massey...
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A62130)
2015 CHEVROLET...
2019 HINO 268 4X2 S/A CURTAIN SIDE BOX TRUCK (A59912)
2019 HINO 268 4X2...
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
2025 44in Hydraulic Grapple Mini Skid Steer Attachment (A61572)
2025 44in...
