plain old belt tightener.
/ plain old belt tightener. #1
firemanpat2910
Platinum Member
Havana Fla
Ford 2910II
Any suggestions on where to find a plain old fashion belt tightener? I have a air compressor that the belt is slipping. Grand pa had a tool that looked like a turn buckle. you put one side against the compressor head, the other against the motor. loosen the motor mounting bolts, turn the buckle to lengthen the tool and it pushed the motor away, tightening the belt. then you tighten the motor mount bolts. I can not find anything simular, looked at harbor freight,TSC, autozone ect.
/ plain old belt tightener. #2
I've seen a mounted 2-eye turnbuckle used for that a lot.
For a portable one, weld the eyes closed, then cut off the end so it looks like a "Y"
Bruce
/ plain old belt tightener. #3
One way I have done it is to cut a block to fit between the motor and the pump. Cut it maybe 1/4" short, then by wedging in a long wrecking bar you will gain the leverage to move it, then tighten. I can tell you though it is much easier if 2 people do it. One pulls the bar, one tightens the bolts.
/ plain old belt tightener. #4
One could easily weld up a pulley pusher from a turnbuckle. Another option readily available is a spring loader pulley belt tensioner like on serpentine belts. Grainger has them. Third option is to weld a bolt onto the motor frame to pull the motor back on the compressor stand like these http://www.overlyhautz.com/.
Belt compound used to be around also, a sticky compound in stick form you held against the running belt that increased friction between belt & pulleys. MikeD74t
/ plain old belt tightener. #6
i always just used a prybar and wood block.. guess a turnbuckle would be fine too :)
soundguy
2010 Ford Crown Victoria Sedan (A61574)
2010 Ford Crown...
2023 Cat 259D3 Skid Steer (A64194)
2023 Cat 259D3...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
2025 Pabreak 80in. Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
Lot 602 (A62613)
Lot 602 (A62613)
Case TV380 (A62177)
Case TV380 (A62177)
