Pizza dough for wood fired oven
   / Pizza dough for wood fired oven #1
bunyip
Elite Member
Flynn Victoria Australia
Kioti DK 5810 HST
Just bought another wood fired pizza oven, we were in two minds as to whether to get a permanent dome or portable and wound up getting a portable unit.
Firebrick base and 304SS inner with a metal outer and insulated in between, it is called a Maximus and comes from Portugal, I have seen an identical unit on Youtube called the Pizza Party with the firebrick facia.
My dough making skills have improved dramatically over the past few weeks with a lot of do's and don'ts but I will share it with you and the step by step process as it does make a difference.
I use the dough making function on the breadmaker because I am too lazy to pull out the Kenwood Chef but they are a trap, they mix well and warm the dough causing it to rise a bit too quickly, for bread it may be fine but the pizza dough rises then collapses on itself and comes out a sticky mess, so here goes:
300g of plain flour
200g of 00 flour
325g water
2 tsp dry yeast
I weigh the first three ingredients as flour density can vary, I weigh the water as I don't trust measuring jugs.
Put the water in the bread maker and add the flour then yeast and set for dough and allow to start mixing, when it is in a ball add about 1/2 to 1 tsp salt and allow it to mix in, when the mix function stops, about 5-10 minutes take it out of the breadmaker and into a lightly oiled covered bowl and allow to proof for at least 4 hours.
Adding the salt improves the structure of the dough, I do not use oil as this impacts on the dough and holds it together and forms a dense mixture, I like pockets of air.
Also I don't use sugar as dry yeast will act in the dry ingredients.
When ready cut into balls, this should yield about 4 nice size pizzas, don't pull the dough apart but cut it as pulling will exclude the air.
Form into balls and allow to rise again for up to an hour covered then form by stretching, a rolling pin will get rid of the air and you will get a flat pizza.
I use a wooden peel to launch the pizza onto the floor of the oven, a light dusting of flour, cornmeal or semolina is all that is needed, the wood is not cold, steel or aluminium is and will draw moisture from the base and cause it to stick, the launch from a wooden peel is both effortless and doesn't deform the base.
Once in I wait about 30 seconds then use a small round SS peel to pick up one side of the base and rotate, it is much easier than a flat peel and a little practice will see you spinning it around to cook evenly, I use the square peel to take it out.
I won't go into toppings as that is a very personal thing but we do go lightly, overload and it will be soggy as it only takes around 60-90 seconds to cook.
We use local gum to fire up but any decent hardwood should work for you, I have used ash, we start cooking when the temp is about 400C.
After cooking pizzas in a conventional oven the difference is amazing, quick and a light char around the edges and puffed up with the air pockets, we suddenly have a lot more friends visiting and offering beer which can only be a good thing.
If I am preaching to the converted, ignore this post but just research on dough structure I think is important and well worth the time I spent seeking the holy grail, it is quite a science
   / Pizza dough for wood fired oven #2
Could you describe what a "breadmaker" is in Australia? On the USA cooking shows, they usually make pizza dough with a stand mixer (Kitchenaid) or a food processor. We also have breadmakers but somehow they are used for mixing and cooking- at least the one was that my ex gave away. Thanks.
The breadmaker mixes and cooks but has other functions too such as just mixing the dough and jam making, there are about 10 pre programmed functions.
I just find it easier to access than the kenwood chef which is much the same as the kitchenaid, my late mothers is still around and in working order, she got it in about 1955 and parts are still available.
The breadmaker we have is smaller and lighter than the mixer and does the job as well, if I use the mixer it would only take about 3-4 minutes with the dough hook.
The planetary action is much the same.
   / Pizza dough for wood fired oven #4
I will check out those breadmakers. The Kitchenaids are around US$200 now and probably made in China. Might be worth it for prolific cooks but not for occasional pizzas. Thanks.
US$200, we wish, with the current exchange rate 1:1.40 (in your favour) we are paying well over AUS$500 for a base model, our Kenwood was purchased in about 1982 and cost over AU$500 then albeit with a blender and mincer, probably also made in China today.
   / Pizza dough for wood fired oven #6
Awesome thread. Thanks for sharing your knowledge and experience. This is soooo far above my abilities. :)
I can't throw the dough in the air, well, I can and am told that it is quite entertaining as it can land anywhere and the shape will depend upon how it lands.
   / Pizza dough for wood fired oven #8
I have complete faith in your abilities in this regard. And would cherish a video.
   / Pizza dough for wood fired oven #9
Most interesting thing about a Kitchenaid to me is that they have a PTO. What's not to like?
I think the two are very similar, remove the front or top cover to put on an attachment and the mixer drive is disengaged, Kitchenaid is popular now but was virtually unheard of (here) when we bought the Kenwood Chef, it is a heavy duty machine, there are cheaper mixers but they just don't perform like the two mentioned.
The downside of the Kenwood is the noise, they sound like the lovechild of a sick Harley Davidson and a Lanz Bulldog, you would swear something is about to break but they all sound the same.
If I had to buy a new one today which would I choose, really don't know as they are very similar in performance and pricing.
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
INOP/NON- RUNNING 2013 Ford F-250 Pickup Truck, VIN # 1FT7W2A61DEA38762 (A51572)
INOP/NON- RUNNING...
2008 CATERPILLAR 226B2 SKID STEER (A51246)
2008 CATERPILLAR...
UNUSED X-STAR 70" QUICK ATTACH MANURE/SNOW PUSHER (A51247)
UNUSED X-STAR 70"...
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
RING 2 STARTS HERE @ 9:30 AM (A51247)
RING 2 STARTS HERE...
