Ballast Pix of concrete filled ballast box
   / Pix of concrete filled ballast box #1
JB4310
Super Member
Central CT
J.D. 4310 E-hydro
Didn't want to at first but needed more ballast for traction in snow and counter weight for heavy pallet fork work.
Six 80# bags of concrete plus metal box makes it about 500 pounds, not sure what it weighed before with 3/4" crushed stone.
Of course I got the idea for the pvc pipe on this site, 1-4", 1-3" and 4-1.5" pipes, while I was doing it I was thinking maybe steel pipe would be better cause if one snaps off your stuck now that it's in concrete, I doubt the 3 or 4" will break, the 4" pipe will hold 4 long handled tools by it self.
   / Pix of concrete filled ballast box #2
Jb4310 , that looks great...:)
I did the same thing , except i used cast iron pipes
to try to keep as much weight as i could. and i ended up
useing only 4 pipes. i thought that was enough for me.
I like the way you painted it. you did a great job.
here is a pic of mine. you can get some nice rubber matting
from Home depot. to give it a nice touch. i find the pipes work good
to hold my logging chains...;)
Chris...:)
   / Pix of concrete filled ballast box #3
Great idea! Now I know what to do with mine.
One question/thought: Do you guys keep these things outside? If so, would water pool up on top or down the pipes, eventually rusting it out? Would some type of weep holes be a good idea? Am I over thinking this?
Thanks for the helpful post and photos.
   / Pix of concrete filled ballast box #4
JB,
Nice job! You'll notice a lot more stability with the concrete-filled box. I just wish I had thought of putting in the pipes before I filled mine! :)
   / Pix of concrete filled ballast box #5
Thats a great place to mount a tool box!
Malvern
   / Pix of concrete filled ballast box #6
Killer_B , I dont know about everyone else. but none of my attachments
stays outside. there all in the garage...;) but my pipes are cast iron
and i welded them in. and there are 5/16 holes drilled in the buttom under the pipe. so water can drain out.
Chris....:)
Chris, I like the steel pipe, looks like 2"? I use mine for the long handled tools like rakes, shovels and brooms etc. but if I catch a limb with a tool the plastic will break, I've got every kind of tool for coring and boring concrete, being a drainage/waterproofing contractor, but it would be a bear to replace one of the pipes now, especially since I used 5000 PSI concrete! I had plenty of steel pipe around oh well didn't have a problem for the last 2 years with the plastic pipes set in stone.
Killer_B, mine is drained also.
JDFANATIC, you could core drill it, a 2" bit is just right for 1.5" pipe, it would be a PITA, you'd have to lay it down so you could drill horizontally.
Malvern, I am thinking about a tool box on the side, want to leave the center open.
How about this, a chainsaw scabbard set in the concrete for the guys who do alot of saw work, I only do a little right now and my small saw will fit in the 3" pipe.
   / Pix of concrete filled ballast box #8
JDFANATIC said:
JB,
I always thought of the FEL as the handy carry all:)
   / Pix of concrete filled ballast box #9
Boxes look real nice, how much do they way just curious.
   / Pix of concrete filled ballast box #10
Depends on what you fill them with. Some people have (7) 80# bags of portland cement. Mine only is only filled 2/3 with clay soil (hard enough now that it might as well be cement). I plan on redoing that when it's cooler outside. I'll probably fill it with crushed stone...
HYD 4N1 PIN ON COMBO BUCKET (A51243)
HYD 4N1 PIN ON...
2011 Ford Utility Econoline Van (A50515)
2011 Ford Utility...
1995 OTTAWA SPOT TRUCK (A50459)
1995 OTTAWA SPOT...
2007 KUBOTA M5040F TRACTOR WITH LOADER (A51243)
2007 KUBOTA M5040F...
Yanmar YM170D Tractor (A50514)
Yanmar YM170D...
UNUSED FUTURE HYD HOSE BUNDLE (A51244)
UNUSED FUTURE HYD...
