Pivoting Draw Bar Attachment Question
   / Pivoting Draw Bar Attachment Question #1
mslisaj
Klamath Falls, Oregon
LS MT125 Loader/Backhoe John Deere Sabre Lawn tractor w/Snow Blade
I have a model 800 Ford tractor. The draw bar is missing but the support bracket is still on the tractor. I got under the tractor today and dug the mud and debris out of what appears to be the attaching point for the draw bar. I can buy a new draw bar from Steiner's but I gather a pin fits up through the bottom and I would slid a hitch pin in the top to hold it. Is that how a draw bar is attached here. it appears a short pin would fit inside that head protector ring and go up through the two brackets and get pinned on the top. I just want to ask you pro's before I go buying the parts that I need.
Thanks for your help. Hope the attached picture helps you to see what I'm working with.
   / Pivoting Draw Bar Attachment Question #2
You are correct, a pin from the bottom through the bracket is what keeps the drawbar in place.
Works for me!! Now I'm working on my second order from Steiner.
Any suggestion where I could find real "parts" for this tractor? The left brake ratchet lock pawl is missing. If I could buy one I would repair that too.
Thanks for the help.
   / Pivoting Draw Bar Attachment Question #4
Just make sure there is not an issue with the drawbar anchor point, like no threads or a broken bolt, before you order.
   / Pivoting Draw Bar Attachment Question #5
Good suggestion but it looks like what happened was the pin that retains the draw bar may have dropped out and the bar pulled against the suport bracket and bent it outward. I can straighten the support bracket in my press and the attaching bracket to the rear end is intact. So all I need is the draw bar and I found the special pin too. So this should be just a job of reassembly after I straighten the support.
Thanks for the advice.
Lisa
   / Pivoting Draw Bar Attachment Question #8
Sounds like an easy fix for you. I've saw the rear support bracket torn loose from the tractor destroying the threaded holes in the process.
Just ordered the parts this mroning. You're description of what you've see is exactly what this looks like. Only difference is the support bracket just got bent and is very repairable. So yes, easy fix.
   / Pivoting Draw Bar Attachment Question #10
Maybe you already said, if so I missed it, where are you getting the drawbar from?
2017 TAKEUCHI TS50V SKID STEER (A52706)
2017 TAKEUCHI...
2016 JOHN DEERE 624K WHEEL LOADER (A51246)
2016 JOHN DEERE...
PALLET OF EXTENSION CORDS AND AIR HOSES (A53843)
PALLET OF...
2015 Chevrolet Silverado Pickup Truck, VIN # 1GB5KYCG0FZ520974 (A53422)
2015 Chevrolet...
2014 SHOP BUILT  DISCHARGE MANIFOLD (A53843)
2014 SHOP BUILT...
John Deere 333E (A47477)
John Deere 333E...
