Pisten Bully 400 service and operations
   / Pisten Bully 400 service and operations
Well guys, I warmed up the bully this morning and thought it sounded funny. I called by boss and gave him all the details and he said "go out and give it a shot anyway". I went less than a mile and it sounded terrible, the engine vibrated to much and it stunk. I called him back and said I think the head gasket is gone so he said to turn around. I'd been adding lots of antifreeze to it the past two times I was out. The other operator is a lose cannon and I can't figure out what he does to it, maintenance wise. The boss came and we looked at it, listened to it and came to the conclusion that HG was gone. Might be out of work from now on.... Said they'll need to get a quote from the Cummings mechanic.
   / Pisten Bully 400 service and operations #262
Your woes are over.
OK, I was in the bully barn for a visit with the Cummings mechanic. Yes, he works for that engine manufacturer. He said we dropped a valve in the last cylinder for an unknown reason. May have got stuck in the open position or some other reason. He wasn't yet sure what had happened but its got serious problems.
   / Pisten Bully 400 service and operations #264
How many hours are on it? Jon
   / Pisten Bully 400 service and operations #266
Nearly 9000. The mechanic thought he'd done some head work on it some 5 years + ago.
Any idea what the life of that engine should be? I know some semi truck engines going for 1 million miles, but I don't know how that would relate to the Bully. Just trying to put it into prospective. Jon
   / Pisten Bully 400 service and operations #267
If you use 30 mph as an average times the 9000 hours it would be under 300,000 miles,
but with a hydraulic drive system it would have seen more work then that.
Then add in multiple operators and hit or miss maintenance.
It would be a hard life for any engine.
The operational speed is closer to 15-+mph... The 2 main drive pump's are seriously worn,, so she is getting tired.
   / Pisten Bully 400 service and operations #269
The 30 mph would be a normal pickup or cars average mph under so called average conditions.
I would expect that the engine in your unit was near peak torque rpm most of the time to run 15 mph.
We have a couple of 8.3 cummins in tractors with over 9000 hours that are still running quite well.
using the 30 mph x 9000 hrs = miles similar to what a pickup would see.
The boss called me today and said he thought the Cummings repairs would be in the 20K area.
FOREST CITY 13' CHOPPER (A52708)
FOREST CITY 13'...
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
2012 SOUTHERN VAC 130 BBL STEEL VACUUM TRAILER (A58214)
2012 SOUTHERN VAC...
GORILLA 2 WHEEL CART W/ HAND TOOLS (A58374)
GORILLA 2 WHEEL...
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
1965 Rogers Low Boy Trailer (A57453)
1965 Rogers Low...
