3-Point Hitch Pipes for rear hydraulic remote valves
   / Pipes for rear hydraulic remote valves #1
Tractorleigh
Kubota B2410
Hi all,
Right, after months of looking for a second hand set of spools on EBay I've eventually come across some, however, they're not Kubota ones.
The valves are a pair of double acting spools and I am trying to mount them to the rear of my B2410.
The tractor has a cab with a cut-out in the rear glass for these.
The problem is, I can't get pipes for them.
I have bought the small square block from Kubota to mount on the rear hydraulics, and after visiting Pirtek (a world wide hydraulic specialist) they have told me they cannot make the fittings due to the block having a small recess on the face.
Any help would be appreciated.
Cheers, Leigh
   / Pipes for rear hydraulic remote valves #2
Can you post a picture of the block, both sides? Sounds like you might have it facing the wrong way.
   / Pipes for rear hydraulic remote valves #3
Perhaps because you have a cab with this specialized cut out (need to see a pic), you need a Kubota OEM valve and pipes (which I take to mean hard piping for the hydraulic connections). I ask the question because I added a two spool valve on my Kubota BX to give me two rear remote outlets and I put it all together from parts I found on surpluscenter.com, including 3000 psi hoses and fittings. So, pending a better understanding of what you're looking for, why can't you go aftermarket for what you need?
2014 Massey Ferguson 9520 (A47164)
2014 Massey...
2006 CATERPILLAR D5G LGP CRAWLER DOZER (A50458)
2006 CATERPILLAR...
Mk Diamond MK-101 Wet Tile Saw (A49461)
Mk Diamond MK-101...
2017 Big Tex Trailer Trailer, VIN # 16VGX2823H6058998 (A48836)
2017 Big Tex...
2017 Ford Taurus SEL Sedan (A48082)
2017 Ford Taurus...
2025 Man Basket Forklift Attachment (A49346)
2025 Man Basket...
