kenmac
Super Member
- Joined
- Feb 13, 2005
- Messages
- 9,961
- Location
- The Heart of Dixie
- Tractor
- McCormick CX105 Kubota MX 5100 HST,
Pipe compound, etc, is only a lubrciate for the threads. Threads actually make the seal to keep a joint from leaking
In Australia nptf is a parallel thread and should use a dowty seal which is a metal ring with a rubber seal built in to the inside...
Some of your information is good and some not so good. The OP asked a simple question about sealing so why mention a fitting (NPTF Dryseal) that there is a 99.99% chance he doesn't have? Or mention it for his knowledge and move on to what he probably has and include your thoughts on sealing.
NPT threads are not expected to seal dry and need a sealant.[/QUOTE]
Not always. Depends entirely on the joining materials. In maleable that's true. In say Delrin, it's not.
I think you're referring to British Standard Pipe (B.S.P.), which is available with tapered (B.S.P.T.) or parallel (B.S.P.P.) threads. The Parallel version uses a washer and O-ring or a bonded seal when it's mated with a port or solid female fitting.
Metric fittings, also parallel thread, commonly use the same sealing method.
N.P.T.F. stands for National Pipe Taper Fuel. It would be highly confusing to use that designation for a parallel thread.
Loctite 592 PST.
Tape SHOULDNT be used, especially on any of the pressure or supply lines...
HOWEVER, lately ive been seeing major issues with chinese sched 40 pipe and fittings being basically crap, and leaking like a sieve no matter what dope was used or tightness achieved.
A trick i learned from an old timer was to smear dope on the threads first, then a wrap or 2 of tape 2-4 threads back from the opening (so you dont contaminate the fluid), then cover that with a layer of dope. You WONT have any leaks after this, even on poorly made fittings. But you muat take extreme care to keep the tape well back from the opening, especially on supply lines to the pump.
Another oldtimers trick was to wrap the threads of the pipe in silk thread along with dope. I havent done the latter, but have had great luck with the above trick on problematic fittings.
I like and use the Loctite PST also.....
a few years ago I replaced my FHW boiler and had troubles getting chinsy black-iron fittings to seal (from Cheapo Depot).....ended up doing exactly that trick with putting dope on threads first, then couple wraps with teflon tape.....it worked...
I wouldn't do it on hyds though......Loctite PST is for that
Also agree with you regarding the hyd adapters made in asia......I sell Gates and they didn't go down in price when the "Made in China" stuff showed up....IIRC I had two price increases this past year.....![]()
Buy at your hydraulic supply house as they will have in stock. You are not going to find this stuff at the big box stores or auto supply stores. Ron
Not sure what you all are doing based on some of the comments.
Old pipefitter talking.
Ron
napa carries a good selection of REAL hyd fittings.. they can order parker.. etc.. I believe napa qua;lifies as an auto supply store no?
soundguy
If you need pipe nipples or fittings on hydraulics, DO NOT USE PLUMBING FITTINGS. Even EX heavy nipples are only rated at 1000 PSI and standard plumbers fittings, black or galvanized are only rated for 150 PSI. Hydraulics are working at 1000-3000 PSI depending on your tractor. Minimum is forged steel fittings and Schd 80 seamless nipples. You get a better quality thread. Buy at your hydraulic supply house as they will have in stock. You are not going to find this stuff at the big box stores or auto supply stores. If you need many nipples and fittings you are better off to use hydraulic tubing and steel hydraulic flatre fittings. One good thing is if the cheap stuff does burst pieces will not fly around like stuff holding air, gases, or steam. But the hot oil sraying around can give some nasty burns.
Ron
Ron, If you read my comments I used the black iron fittings on a FHW (forced hot water) boiler......at no time have I suggested anything other than "Real" hydraulic fittings for hyd systems........the hydraulic fittings that I referenced made in china are from Gates, Aeroquip and Parker.....
Old Hydraulic Technician Talking
Bill
From the OEM standpoint, leaks equal mechanic visits and warranty claims. Number 1 way to avoid hydraulic line leaks is to avoid pipe threads and instead use ORB (o-ring boss) ports and ORFS (o-ring face seal) connectors. If, however, you are forced to use pipe threads because nobody makes what you need with the preferred, always use a thread sealant. The 3 large OEMs for whom I worked all used the same thing for pipe threads - whichever Loctite hydraulic sealant was best at the time. At one time we had a rash of hydraulic motor shaft seal leaks from 1 plant (identical machine built at 3 plants worldwide and only the US built machines leaked). We had a bunch of the leaky motors returned - bits of teflon in the seals causing the leaks. Investigate the assembly line - someone had decided to change from sealant to Teflon tape on the sole pipe fitting used on the machine and the teflon tape chemically matched the bits found in the seal. Change from tape back to the specified sealant and problem resolved.
