pipe thread?
   / pipe thread? #1
rayclar
prince township , ontario, canada
kubota 4310hstc
When installing hydraulic fittings with one end pipe thread should i use tee tape there or just use the fitting bare?
   / pipe thread? #3
I use teflon tape for all tose sort of things, air lines, water lines, ect..
   / pipe thread? #4
Loctite makes a sealant for use with NPT threads in hydraulic systems. We use it in plant maintenane w/o leaks.
   / pipe thread? #5
If you use too much tape you can break/crack the fitting.
Always err on the side of liquid pipe dope as long as the fitting is a low pressure fitting only.
   / pipe thread? #6
I would recommend using a sealant/lubricant on all NPT pipe fittings.
   / pipe thread? #7
i like gasoila... I HATE tape.
tape threads block small prts when it shreds.. and solvents won't remove shreded tef tape inside small valves...
soundguy
   / pipe thread? #8
Years ago I learned from a heavy equipment master mechanic to use the black Permatex gasket sealant on hydraulic fittings. He also said never use teflon tape, excellent way to take out a pump!
   / pipe thread? #9
I like the heavy white teflon paste. Excellent lubricant and thread sealer without the possibility of shredded teflon getting into your system later. That said, properly applied T tape will not harm your system on initial installation. Where you get the problem is when you have to remove a connection that has had tape in the threads. It is almost impossible to get all of the tape out of the female connection without some special brushes. Avoid all that with the paste. A bit messy but just as effective.
   / pipe thread? #10
Loctite 592 PST.
Tape SHOULDNT be used, especially on any of the pressure or supply lines...
HOWEVER, lately ive been seeing major issues with chinese sched 40 pipe and fittings being basically crap, and leaking like a sieve no matter what dope was used or tightness achieved.
A trick i learned from an old timer was to smear dope on the threads first, then a wrap or 2 of tape 2-4 threads back from the opening (so you dont contaminate the fluid), then cover that with a layer of dope. You WONT have any leaks after this, even on poorly made fittings. But you muat take extreme care to keep the tape well back from the opening, especially on supply lines to the pump.
Another oldtimers trick was to wrap the threads of the pipe in silk thread along with dope. I havent done the latter, but have had great luck with the above trick on problematic fittings.
2015 ISUZU NPR 16FT BOX TRUCK (A54313)
2015 ISUZU NPR...
CHALLENGER VACUUM PUMP (A53843)
CHALLENGER VACUUM...
2006 FORD F-250(INOPERABLE) (A53843)
2006 FORD...
JOHN DEERE 7210R TRACTOR (A51247)
JOHN DEERE 7210R...
2014 KENWORTH T800 KILL TRUCK (A53843)
2014 KENWORTH T800...
2014 10ft T/A Dump Trailer (A51691)
2014 10ft T/A Dump...
