Pipe Insulation
/ Pipe Insulation #1
scootr
Super Member
Temecula California
Kubota MX5200 HST, 773 Bobcat, Cat forklift
What type of pipe insulation do you use for water lines and how effective is it? What about longevity?
I've used the foam tubes but they degrade in sunlight. Is pipe wrapping better? If so, which one?
I've got some new 2" PVC lines at the well tank and pump that need some protection.
/ Pipe Insulation #2
Why not slit a piece of flexible drain pipe and slide it over the pipes after you insulate them with foam tubes?
/ Pipe Insulation
That would keep the sun off of the foam...
/ Pipe Insulation #4
They also make line hiders for Mini Split HVAC units if you want something that looks decent, but those things are maybe $60+
/ Pipe Insulation #6
My only insulation need are hydrants scattered out through property, and I use a combination of foam insulation secured with tape and a section of waste PVC pipe slipped over that and a hole drilled in side for valve and topped with a cap.... Keeps sun and rodents from destroying insulation....
2010 Chevrolet Camaro Coupe (A66738)
2010 Chevrolet...
2014 Ford Escape SUV (A66738)
2014 Ford Escape...
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
2003 Ford F-350 4x4 Crew Cab Flatbed Truck (A66736)
2003 Ford F-350...
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
2023 Unused Unverferth Air Top SPTATV001B 200 Gallon T/A Towable Boom Tractor Sprayer (A66734)
2023 Unused...
