Pipe Fence Questions
   / Pipe Fence Questions #1
930dreamer
Ford 841 Power Master
Hello everyone, I found this forum while searching for pipe fence ideas.. I have a new to me 4 acre piece of land that needs a fence in front. it's 400' across the front, I see a CL ad for Schedule 80 new pipe for $32 for 32' and 8 ' for $10. I'm trying to figure out materials needed;
400' / 8' = 50 8 ft posts minus two gates
400'/ 32' = 13 32 ft pipe(rounded up) for top rail minus two gates
18 8 ft horizontal pipes per ten posts = 90 8 ft pipes minus two gates
Am I close here?
   / Pipe Fence Questions #2
Local fence company gets about a 2 -1/4 inch diameter steel oil field pipe (surplus-used) by the pallet load (actual bundle), they use it for posts and top rails and use "sucker rod" (3/4 solid bar) between post to make lower "rails" for live stock containment....
See no reason for schedule 80 new when its just going to rust over time.... Look into "salvage/surplus" sources...
IF livestock containment is more important then aesthetics (yes we want it to look good also), you can use 4X20 foot live stock panels between posts to create barrier to keep animals in.....
In the end its probably going to be cheaper to get long length and cut it to length for what you need....You probably will save enough to buy cut off saw and still save money...
I personally like the rust color country look....
Dale
   / Pipe Fence Questions #3
All depends on where you are.
Dollar a foot ain't bad.
   / Pipe Fence Questions #4
Dale
Dale,
I read on some forum about how oil well pipe or stem or drill rod became radioactive from uranium in the ground. The post told how junk yards in oil country have radiation detectors (Geiger Counters?) next to the scale and won't buy the metal for scrap. Is this true where you live. As far as I know there are no oil wells in my state so I'm ignorant on the subject and can't understand why all oil products aren't radioactive.
   / Pipe Fence Questions #5
I have heard that that story too, but I have yet to see any fences that glow in the dark or any of local fence workers growing third eye in forehead..... There might be some truth to the radioactive thing, but I believe with all the safety rules in place today you would be pretty safe working with responsible salvage dealers...
Dale
   / Pipe Fence Questions #6
If you can find brand new schedule 80 pipe for a buck a foot, you should buy all of it!!!! Around here, that's what used 2 3/8"s oil field pipe sells for with a poor rating. All used pipe is painted with a color coding to indicate how good or how bad it is. I forget what each color means, but it's easy enough to look up if you needed to.
Around here, pipe fences are very common and in all types of condition. Friends that build fences refuse to work with used pipe because you never know what you are dealing with, or where the super thin sport are. A lot of the do it yourselfers will buy the used pipe and hope for the best.
You didn't say what your soil is like. If you use an 8 foot post, will you be able to go down deep enough to deal with expansive soil? Do you have snow or freezing weather to deal with? Where I live, red clay, iron ore and sugar sand are the most common type so soil to deal with and usually 3 feet deep is plenty for a fence. If you go towards Dallas, the soil becomes a black type of clay that is extremely expansive and very difficult to work with. Posts need to be at least 4 feet deep with 5 feet giving you better results. It's really crazy seeing how badly some fences and power poles have moved over the years because of the soil there!!!
For doing the math, I always use graph paper and figure it out there. How many gates, how wide will they be, will there be any other interior fences? After I draw it all out to scale, it becomes real easy to work out a materials list.
   / Pipe Fence Questions #7
Dale
Dale,
Thank you. Saw that information several years ago and have been curious ever since.
   / Pipe Fence Questions #8
Every time I've brought pipe to the scrapyard, they check it for radioactivity.
I've always bought new pipe (actually 2 3/8" structural tubing, just because it's round, it's not always classified as pipe). That's what most folks use around here. It has a slightly thinner wall than SCH40. It costs more, but you know what you're getting and it's easier to handle, cut, drill and grind. I've had a pipe fence on my property for about 20 years. I had to modify a section earlier this week and dug up a few of the poles. They were still in good shape with minimal corrosion below ground.
   / Pipe Fence Questions #9
Am I close here?
Always add one post for the starting end
   / Pipe Fence Questions #10
Drill pipe you can get cheap is worn out. If it wasnt, they would be still using it. I assume the color code stuff is true, at least in some areas.
Not sure if there is any truth to the radioactivity rumors, but there is plenty of salt down there & other corrosion inducing chemicals used. Even if it looks good on the outside it's likely rotting from the inside. I'd be mighty skeptical about good deals on "new" pipe, or any deals with used pipe.
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
2020 FREIGHTLINER M2 SERVICE TRUCK (A58214)
2020 FREIGHTLINER...
2013 John Deere 245G LC (A55272)
2013 John Deere...
2014 Dodge Ram 4500 Versalift Bucket Truck (A55973)
2014 Dodge Ram...
4 Unused Montreal ST205/75R15 Trailer Tires (A55787)
4 Unused Montreal...
