pipe dope?
   / pipe dope? #1
ctgoldwing
Platinum Member
Central Connecticut
L3800HST
One of the hydraulic hoses for my fel has a very small leak at the threaded fitting end. I am planning on removing all the connectors in the area and re-doping the threads. The question is - what to use for pipe dope? I would generally not use teflon tape but what is the best thread sealant?
   / pipe dope? #3
If you are careful while applying it any thread sealant will work. Try to not get any inside of the fittings. Remember, Teflon is also a lubricant so it is easier to overtighten threads and break castings etc..
I have had the best luck with loctite thread sealant but it requires the threads be clean and oil free.
Roy
   / pipe dope? #5
I have tried the permatex high temp thread sealent on my hydrolics. My experience is that it works, but with strong leaks it only works for 20-25 hours of run time before it starts leaking again (happened multiple times). The locktite is better, but I would be hesitant to use it on anything I would like to take back off any time soon.
   / pipe dope? #6
When I had a leak in the hydraulic fittings on my new scut ..........the dealer sent a mechanic and he used pipe dope on the threads to seal it. He told me that in his opinion the stuff sold by Napa was the best. The technique works.
2019 TEREX PHOENIX 2100 TROMMEL SCREEN (A53426)
2019 TEREX PHOENIX...
2016 Isuzu NPR Landscape Dump Truck (A51691)
2016 Isuzu NPR...
40' High Cube Multi-Door Container (A50123)
40' High Cube...
Vermeer 504 I Round Bailer (A52384)
Vermeer 504 I...
2012 Freightliner M2 106 Braun Ambulance (A51692)
2012 Freightliner...
1981 LUFKIN FLATBED WINCH TRAILER (A53843)
1981 LUFKIN...
