Pipe couplings
/ Pipe couplings #1
LongJohn01
Newcastle, NSW
Massey Ferguson 135
Hi I've got some old aluminium pipes I want to change couplings on. They look like old southern cross couplings. Does anyone have any tips on how to get these off without damaging the ends of the pipes.
/ Pipe couplings #2
I would use a torch a put some heat on threads before trying to loosen them up.
/ Pipe couplings #3
Looks like it's the same idea as the push-on quick connect fuel lines that Ford uses...grab a pop can, and cut a strip of aluminum, wrap it around the pipe next to the fitting, then slide it sideways into the fitting to release the spring? I would think heat might melt the plastic inside.
/ Pipe couplings #4
Hard to get a reference of just how big of a pipe that is.
Is that a close up pic of a 2" pipe? or is that a 10" pipe?
My method of attack would be totally different between a 2-3" pipe vs a 8-12" pipe
(2) Bell 500 Gal Saddle Tanks (A64119)
(2) Bell 500 Gal...
2003 HRTO 14ft. Enclosed S/A Trailer (A61574)
2003 HRTO 14ft...
Willmar Fabrication 915 (A64119)
Willmar...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2017 Load Trail 22ft. 7 Ton T/A Equipment Tilt Trailer (A61568)
2017 Load Trail...
2014 John Deere 1025R (A64126)
2014 John Deere...
