Pins Clips Not Standard?
/ Pins Clips Not Standard? #1
CBB
Just north of the PA line in NY
JD 5320N Vineyard, 1981 Deere 910, 1980 Kubota B22, 1983 Ford 1710
I have had a pin clip (a pin with the metal circle that flips over to keep the pin in) vibrate out of the pins that hold the bucket on my ck20. We have a number of the pin clips hanging on the wall of the barn we use with the Kubotas, Ford and JD. I'll be darned if those pins on the wall are a shade to fat to fit in the pin holes. I don't mind going to the dealer to buy some just for this one tractor but I found it odd and a bit idiotic. For now I just stuck a bolt and nut through to hold the pin in place. Am I missing something about the pin clip size?
/ Pins Clips Not Standard? #3
I never gave that a thought that the size may be different. I was in my local TSC store a while back and they had a bin full at the checkout. I think they were only 10-15 cents each at the time so I picked up a dozen for spares, put some on each implement and extras in the tool box.
Odd that only Kioti would choose to use this size. I like being able to use the same pins for any of the tractors.
Lots of pluses to the Kioti. This counts as a minor minus.
I will pick up some pins but won't hold my breath on the price being 15 cents each for hardened steel.
/ Pins Clips Not Standard? #5
What do you think about drilling them out a super minor amount just to allow the fatty to fit? I was able to fit the standard non-metric 15 center in to the bucket holes on my 30 without drilling but it is a bit tighter than the OEM pins.
/ Pins Clips Not Standard? #6
I doubt it would hurt to ummmm clean up the casting material off of the inside of the hole <wink>.
What we tell customers to do now is put the ones from the 3 point top link pin in their tool box and we give them extra ones to replace those.
That way they have at least 2 extras for the loader.
BTI
/ Pins Clips Not Standard? #7
I had the samething happen to me, I just dilled the holes out to fit the larger pins. Then lost one of those! So now I "zip tie" the rings to the pins so they won't come open and fall out, I also do the "hair pins" on the underside of the tractor. had many weeds and brush yank these out!
Great suggestions. Thanks. I will implement each.
International 806 Wheatland Tractor (A66285)
International 806...
1986 Trailmobile 40Ft F71T-6UJA Trailer (A64194)
1986 Trailmobile...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
213133 (A64276)
213133 (A64276)
