Will
Does anyone have any tricks for pinning up a MMM on a B2410? I've got the mower adjusted so that pin holes almost line up when I lift the 3 point hitch all of the way, but it is still a pain in the neck crawling around on the ground with my arm under the tractor trying to plug the small pin in that holds it up. Even worse is trying to line the spring clip up with the hole in the pin and attach it by feel. Has anyone figured out a better technique? Or has anyone found/made a pin with a handle to hold up their MMM?
