Pinng up a Kubota MMM/B7610
   / Pinng up a Kubota MMM/B7610 #1
Trap
Northeast KS
Kubota B7610,
Has anyone ever tried locking up a 60" Kubota mmm to do some loader work? the book says to raise the deck (impossible to get that high) and pin the front of the deck with supplied pins into brackets. It is almost impossible to lift a 300 lb deck & place pins. It also looks to be very close to rubbing on rear tires if it is locked up. Any help on using 3 pt with MMM installed on a B7610 will be appreciated. Gotta go ........
   / Pinng up a Kubota MMM/B7610 #2
I was having the same thoughts with a B2910 and 60" MMM I bought used. After a year of owning it, I used it as it was but never felt it was set up right (and having the same problem as you are), I finally broke out the owners manual last weekend and followed the instructions to set up the front and rear lift linkages. Now the mower lifts correctly and the pins can be put in place without any trouble.
My guess would be your mower is set up improperly as mine was.
   / Pinng up a Kubota MMM/B7610 #3
Sal's got the answer, Trap. It has to be set up right to get the pins in. I used my roll-around floor jack the first time and raised it into position with that. Even then I had to do a little grinding to get one of the pins to go in...the other one slipped in easily once the jack held it in position.
The next time around I decided to check out the setup and found that the connecting rods that go forward from the 3 pt. hitch arms needed to be shortened as specified in the Mower Adjustments section of the mower manual (mine's an RCK60-24B on a B7610). Basically you shorten them until the holes line up on the front hanger brackets and the rear stoppers are either just touching the frame (left side) or clearing the frame by about 1/4" (right side). You should refer to your manual so that you know exactly what parts these are and where the clearance is measured.
After mowing I noticed my adjustment had been lost and the left side of the mower deck was very close to rubbing the left rear tire when raised. After fiddling with connecting rod adjustment again, it dawned on me that the adjustable right side lifting rod (turnbuckle) on the three point hitch wasn't locked and that the right side 3pt hitch arm was sagging. As a result, the right side of the mower was sagging when raised levering the left side up and nearly into contact with the tire. So before making your connecting rod adjustments, level up your 3pt. hitch arms and lock the hitch turnbuckle.
I'm surprised that the mower manual doesn't mention that right-side connecting rod adjustments are dependent on the hitch turnbuckle setting. If, after setting connecting rod length correctly, you were to raise the right side hitch arm by shortening the turnbuckle, you could easily overstress or possibly break the mower lift linkage.
Even when set up correctly (I think), the rear of the mower deck only clears the left tire by a few millimeters. When parked on a slope it sometimes appears to touch, though I've not yet seen any rub marks. As part of setup, the I feel the dealer should've made sure that the pins could be easily inserted and removed. If they'd done this, they would've known that the mower connecting rod setup was wrong. They should have also warned me about changing the length of the 3pt. hitch turnbuckle. Apparently this is something that's not stressed in their training.
FWIW
Bob
   / Pinng up a Kubota MMM/B7610 #4
Once you raise the mower all the way up, it should only be about 1" away from the hangers. When I had my MMM, I used to squat down with a pin in my right hand, lift up the right end of the MMM with my left hand and place the right pin in. Then I would go around to the left and repeat. Took all of about 90 seconds. How high are you having to lift?
   / Pinng up a Kubota MMM/B7610 #5
You strong man, Chris. I couldn't do that, certainly not with one hand. The hydraulic floor jack worked OK, though.
   / Pinng up a Kubota MMM/B7610 #6
Hi All,
I don't have a mmm so please excuse me if my question is too basic. With the mmm in the up-and-locked position, can the 3pt lift be used for grading with a box or blade?
   / Pinng up a Kubota MMM/B7610 #7
Pks,
Short answer: yes
Long answer: you may want to take the mmm off the tractor to keep from dragging it through the stuff you are trying to grade.
Bob
2015 Ford Econoline Shuttle Bus (A50323)
2015 Ford...
John Deere 4044M (A50120)
John Deere 4044M...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2017 FREIGHTLINER...
2008 BMW 535xi AWD Sedan (A50324)
2008 BMW 535xi AWD...
ATTENTION PLEASE READ (A50120)
ATTENTION PLEASE...
