Pinhole leak in hydraulic line on backhoe. There a clamp or sleeve fix?
/ Pinhole leak in hydraulic line on backhoe. There a clamp or sleeve fix? #1
Woodsman603
Bronze Member
North Country
Kubota L3710
Woods9000 on my L3710. There's a pinhole leak on one of the lines. Its one of the longest lines on the setup too. No idea how the pinhole got there, but its away from all mounting surfaces, bends, couplings, or anything. Right on the "straightaway" on the line. Easy access, right there.
Is there a clamp, sleeve, or something else that would hold up? Sure, I can replace the entire line, but the fact its dead nuts on a straight portion of the line and wide open access, makes me wonder if there is something else that can be done before I rip the whole thing out.
Thanks.
/ Pinhole leak in hydraulic line on backhoe. There a clamp or sleeve fix? #2
There is a "Hosepatch", but its more for emergency use until you can go get a new hose, I remember coming across this one a few months ago and filed it away...
Not cheap but its reusable. Someone may know of a cheaper one time use product.
NOTE: there are different sizes - this link takes you right to the 1/4" size....
Ah, that's sort of the thing I had in mind. For $150, I'll replace the entire line.
Just the one time the issue is right there, easy access, in plain sight view that I was hoping for a fix.
/ Pinhole leak in hydraulic line on backhoe. There a clamp or sleeve fix? #4
/ Pinhole leak in hydraulic line on backhoe. There a clamp or sleeve fix? #5
That's a good option, or remove the hose and take it to shop for a splice fitting. Clamping the outside of the hose is not likely to seal enough to keep the fluid under pressure from migration along the wire and then rupturing the outer jacket again.
/ Pinhole leak in hydraulic line on backhoe. There a clamp or sleeve fix? #6
Is this a hose or a steel line? I think some are confused on that. Steel line, if the leak is at all accessible, I would probably try just brazing up the hole. Have done that many many times and most are still out there running. Unless the hole is on the bottom, I wouldn't bother taking it off. I've brazed lines with oil inside before without issue. Just open up a fitting one end and drain the line down a little so it's not full right where you're working. It will smoke a little but no harm will come from it.
/ Pinhole leak in hydraulic line on backhoe. There a clamp or sleeve fix? #7
Thanks.
Another option for probably less than 1/2 of buying it all preassembled would be buy a hose assembly of the proper length with two NPT ends on it . Then buy the end fittings to thread on that match your original end fittings. Depending on the situation it’s usually easier to install if you buy the hose assembly with one end NPT Swivel.
Last one I bought was actually a Gates brand hose assembly from a local Family Farm and home. I’ve had good luck with these . Another nice thing if the hose ever goes bad you just very easily and inexpensively replace it. Been my experience the hose even the top quality ones end up failing before the end fittings.
/ Pinhole leak in hydraulic line on backhoe. There a clamp or sleeve fix? #8
Very valid. I had been thinking hose, but after re-reading OPs post wording makes me think its steel... thus rendering amazon splices useless here...
Ah, good point.
Yea, this is a hose. Flexes and stuff.
Those splices, so cut the line before and after the pinhole, then put those ends in then. That may be an option too.
/ Pinhole leak in hydraulic line on backhoe. There a clamp or sleeve fix? #11
Yep. I also assumed hose. Like Harry said braze it if steel. I too have repaired steel lines on my backhoe by brazing. TIG brazing but still brazing. Worked great.
Eric
/ Pinhole leak in hydraulic line on backhoe. There a clamp or sleeve fix? #12
The splices thread in to the hose. They are kinda tough to turn but work great. And are a permanent fix. Down the road if you replace the hose just unscrew the splices and save them for another repair.
Eric
/ Pinhole leak in hydraulic line on backhoe. There a clamp or sleeve fix? #13
Seems most of the reviews are from getting a free product. How do I get a free product? :)
If it leaks and does not work, the seller refunds the money and alters the review to their specifications. XD
Follow up question on those reusable hoses, what am I using to cut the existing hose? Straight up angle grinder?
/ Pinhole leak in hydraulic line on backhoe. There a clamp or sleeve fix? #16
If this is a pressure hose I would verify the splice is designed for your brand of hose since not all hose is made to the same specs on ID & OD.
Most good hydraulic hose shops won’t crimp new fitting on old hose or at least they won’t in this area.
/ Pinhole leak in hydraulic line on backhoe. There a clamp or sleeve fix? #17
Hacksaw or angle grinder. Clean the inside of the hose very well. The angle grinder is way easier than a hacksaw.
Eric
/ Pinhole leak in hydraulic line on backhoe. There a clamp or sleeve fix? #18
Go an hydraulic shop or any other place that makes hoses with the old hose, get a new one made and don't worry about it.
Cost me $12 or $13 and 10 minutes to get a new hose made just the other day.
I may just go this route. Remove the line, have a new one made. While I'm there, have them splice in a new line at the pin hole on the old line. I'll have a new line in, and have a spare.
I was just shooting for a quick clamp or something using a sleeve and some ubolts or something.
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
2014 Dodge Journey Van (A59231)
2014 Dodge Journey...
2002 Freightliner FL112 S/A Day Cab Truck Tractor (A59230)
2002 Freightliner...
2019 MERTZ MANUFACTURING MANIFOLD TRAILER (A58216)
2019 MERTZ...
2013 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59230)
2013 Chevrolet...
