pin type brakes
/ pin type brakes #1
RegL
Platinum Member
Northwestern CT
PT 1430
I have a 1430 with one break working and a 2430 with no breaks. Does anyone know if it's the cables that freeze up or the pin in cylinder mechanism. I've tried spraying with wd40 to no avail. Thanks.
Reg
/ pin type brakes #2
I had the same problem. I sprayed with PB Blaster (WD40 really isn't a penetrating oil) and whacked the pins with a punch and hammer. Once they started moving, I sprayed them with a teflon lubricant (WD40 isn't much of a lubricant either.)
Hope that helps.
/ pin type brakes
Hope that helps.
I've tried the PB Blaster but not the punch and hammer. I'll give that a try. I assume if that don't work I should go with a bigger hammer?
/ pin type brakes #4
Actually, yes! Don't be afraid to whack it pretty hard - I started with a 2 pound hammer and wouldn't have hesitated to use a 4 pounder. I learned long ago that pounding long and hard with a small hammer will mushroom a stuck shaft where a few licks with a big one will knock it loose.
/ pin type brakes #5
Rust has probably settled around the pins and housing. Remove then and wire brush or sand them smooth, and re-grease. and install.
2005 Sterling Acterra Tender Truck (A63688)
2005 Sterling...
2011 Ford Expedition SUV (A61574)
2011 Ford...
2012 CATERPILLAR 259B3 SKID STEER (A64279)
2012 CATERPILLAR...
CASE INTERNATIONAL 3900 DISC HARROW (A63291)
CASE INTERNATIONAL...
10 ft bed. 14 ft trailer (A61567)
10 ft bed. 14 ft...
Lucknow 360 Feed Wagon (A63688)
Lucknow 360 Feed...
