Snow Pin On Blade for KL102?
   / Pin On Blade for KL102? #1
dlpritts
Central Pennsylvania
Kioti lb1914
I 've found several blades on the net but none listed as specifically for the KL102. Does anyone have experience with and/or a recommendation for a pin-on snow blade that fits the KL102 FEL?
   / Pin On Blade for KL102? #2
Is the KL-102 a QA loader? If so there are various companies that make QA snow blades, some with manual angle others with hydraulic angle.
   / Pin On Blade for KL102? #4
Try Michagan Iron
   / Pin On Blade for KL102? #5
Thanks CM.
Unfortunely, my KL102 is not QA.
You're welcome. And I second what EHR said. Michigan Iron is great to deal with, and if they don't have something for you they should be able to refer you somewhere that will have what you need.
   / Pin On Blade for KL102? #6
Yep, we can do a Pin-on Snow Blade for the KL102 Loader. Contact us if you would like more information.
If you visit our website, the pricing and information on our Plow Packages is under the Snow Plow / Grader Blade button.
(4) Master Craft 235/65R17 Tires With Rims (A55272)
(4) Master Craft...
10 X6 MANIFOLD (A58214)
10 X6 MANIFOLD...
Homelite 26B Leaf Blower (A57454)
Homelite 26B Leaf...
2017 BX2680 Sub Compact Utility Tractor (A56436)
2017 BX2680 Sub...
Takeuchi TB216 (A57148)
Takeuchi TB216...
2019 ALLMAND LIGHT TOWER(INOPERABLE) (A58216)
2019 ALLMAND LIGHT...
