Backhoe pin issues on BH75
/ pin issues on BH75 #1
ozman
Averill Park, NY
Kubota L3400
Hi everyone,
Has anyone experienced problems with keeping the pins in on the stabilizer pads with the BH75 backhoe? With the movement of the machine sometimes I end up loosing the snap ring that holds the pin in on the pad.
Is there a solution to correct it? I was thinking about welding a large washer on one end to keep it from sliding out, but then the other side has a snap ring too, so I'm at a loss for a solution. Any tips would be greatly apprieciated!
Mark
/ pin issues on BH75 #2
I have the same back hoe on my L3400 and have not had a problem. Snap rings can be a pain if they don't seat correctly. Try a new set but make sure you have a good snap ring tool because without it that can cause the ring to deform and you will have the same problem.
Shadman, thanks for the reply.
I just picked up a new set of snap rings. I'll give it another shot at it. I wish the pins were like the pins that are on the loader with a bolt going through them so there's no chance of it pulling out.
SCAN TO RECEIVE TEXT UPDATES (A64278)
SCAN TO RECEIVE...
2018 Ford Escape SUV (A64557)
2018 Ford Escape...
2016 Isuzu NPR 20ft Box Truck (A64556)
2016 Isuzu NPR...
2015 DODGE MINI VAN (A63290)
2015 DODGE MINI...
2022 EZ-GO ELITE...
UNVERFERTH 6R36" RIPPER / STRIPPER (A64278)
UNVERFERTH 6R36"...
