Backhoe Pin/Bushing replacement in Woods 750 Backhoe
   / Pin/Bushing replacement in Woods 750 Backhoe #1
Dataway
Greenfield TN
Ford 1715, BX2200
I've got my woods 750 disassembled, the holes in the boom and dipper are shot (sure wish they didn't use hardened pins).
Plan is to get them in the milling machine and take the holes out to 1 1/4" and bush them. They use 1" pins.
Any tips, hints, ideas, advice on bushing material, machining, clearances etc??
Also need to replace the lower bearing in the pivot housing ... anyone done that before?
Thank you for your expertise.
JohnnyB
PS. Can I get away with high load bronze bushings ... or should I use hardened steel like a "drill bushing" Only issue with the hardened steel is the hole in the booms would have to be spot on because I couldn't adjust the OD of the hardened steel bushing on the lathe.
   / Pin/Bushing replacement in Woods 750 Backhoe #3
You should be able to order a pin kit that has the bushing, and pin with zerk fitting in one nice package.
The Woods 750-3 does not use bushings like were used on the earlier models. I have found the bushings are available for the earlier models, same diameter pin, bushing is ID 1.00 x OD 1.24 x Length 1.5" .... so... that should work in the later boom and dipper if I bore out the booms. What I am wondering is if these earlier model bushings are hardened steel ... not sure about using hardened steel bushings with a hardened steel pin ?? Might be ok, I'm not sure.
Looks like if want to rebuild it using OEM parts I can use the various bushings that were used in the early 750's, and OEM pins from the later model 750's. But again ... would have to bore out the booms ... but would have to do that anyway. Assuming the early model bushings are hardened steel ... I'm going to have to hold the boring to probably .001" accuracy to get the press fit right.
Sure wish they kept building them like the early models that had bushings in all the necessary locations.
Might have to fabricate a couple of the pins that for some reason are priced crazy .... like $150. Most of the pins run around $40 which is fine.
Or are you saying someone sells a retro-fit / repair pin and bushing kit?
There is no bushing on that model of the BH750 .... they stopped using bushings at some point earlier.
I know where to find the early model bushings. That's the easy part. The hard part is modifying a 750-3 to take the bushings.
And I'm not sure if the early model bushings are compatible with the late model pins .... as far as hardening goes ... and I can't use the early pins because they are different length.
Basically I'm looking for advice on the machining, bushing fit, pin hardness etc. from someone who has done this before.
   / Pin/Bushing replacement in Woods 750 Backhoe #7
go find a company that services logging equipment. they might,should be able to help you.
   / Pin/Bushing replacement in Woods 750 Backhoe #8
JohnnyB
IMO, something, somewhere has to have some give to it. Picking what and where is the hard part. When possible, I've been using these NU series Self-Lubricating Bearings and Bushings - National Precision Bearing. That way if someone forgets to lube, ok and if they do lube, ok.
I would not use hardened bushings with hardened pins.
   / Pin/Bushing replacement in Woods 750 Backhoe #9
I wouldnt use bronze on the bushings. It pounds out and deforms quickly.
The only hoes I have worked on have been industrial machines so I dont know what is typical in smaller ones. But industrial stuff use both hard bushings AND pins. With the tins being only slightly softer. Reason is the pin is usually the easiest to make, and replace. The pin is hard....not so much for wear resistance, rather toughness. You dont want a soft carbon/mild steel pin in there. They bend and break too easy.
When I did mine, I used either 4140 or 4340 pre-hardened. It was about 50Rc. I dont see what the big deal is about adjusting a bushing in the lathe even if hard. At least up to about Rc60. Do you not have carbide tooling? If not, get some.
As to the wear, what caused it? Lack of grease? No grease getting to the pivot? How is your pins set up? I have seen some that can free spin through everything and has necessary grease points, and retained with snaprings. Others are captured pins with a tab and retaining bolt or similar, that are only allowed to spin in one of the connections points. Those types of pins only need to worry about bushing and grease holes on the part that spins.
There are a ton of good material choices for pins and bushings. o1 drill rod (hardened), 1144 stressproof, 4140/4340 steels, hydraulic cylinder rods, etc. On a machine that size with 1" pins....dont know how long they are....but I would't be at all opposed to using a 1" shoulder bolt. Already pretty hard and tough, and nicely machined. Just avoid mild steels and brasses/bronzes
Thank you guys for the advice.
I did find some OEM bushing for a earlier model that I'm going to assume are the right material (but again designed for a machine was made to accept them)
For the areas that were not ever bushed on any model (the ram pivots) was thinking high load bronze, 40,000 lb when using a pair of them.
Shoulder bolts ... great idea. I had planned on making a couple of ram pins with "high strength" 1045 medium carbon rod, but I see McMaster has shoulder bolts that would probably work with modification.
I do have carbide tooling ... but last time I tried to turn something hardened (case hardened) it didn't go very smoothly.
I guess I could also just order the earlier model bushings and modify their length to use in the ram pivots also.
Most of the pins are clevis type ... just slide through, pin to a flange on the outside of the boom. ... so yes, pinned on one side, free on the other side of the connection. All the ram pins are pinned in the boom pivot hole, free with grease fittings on the end of the cylinders.
I've had this machine for 10 years, but it was a rental before I got it .... damage was done due to lack of lube before I got it.
Being a small Woods BH, it's not the highest quality piece of equipment out there, just trying to tighten it up enough that I it doesn't look like it has palsy when it operated :)
2007 MERTZ FRAC BLENDER TRAILER (A45333)
2007 MERTZ FRAC...
2012 CAT D5K2 Dozer (A42203)
2012 CAT D5K2...
2016 Subaru Impreza AWD Hatchback (A42744)
2016 Subaru...
2015 FREIGHTLINER CORONADO 122 SD (A45333)
2015 FREIGHTLINER...
2012 Dodge Charger Sedan (A42744)
2012 Dodge Charger...
33ft Box Trailer (A44391)
33ft Box Trailer...
