Pin and Bushing help needed
   / Pin and Bushing help needed #1
EddieWalker
Epic Contributor
Tyler, Texas
Several, all used and abused.
My grapple works pretty good, but not great. I've come up with a few ideas that might cut down on my problems, but haven't had any luck finding what I think I need.
My problem is that I have two seperat arms that close on my FEL to create a grapple. Each one works independent of the other. What is happening is they are twisting and bending on me. I've reiforced them to the point they are too heavy to install and they are still bending.
I'm now going to try 2x4 steel tubing.
The other problem is the pivot point. I just drilled holes through half inch steel and put a grade 8 bolt through there to pivot on. I'm using a one inch bolt, and that seems to be plenty strong enough, but my grapple wobbles on it. This movement allows the grapple to twist and in turn, bend.
My solution is to make the end of the 2x4 tubing like the end of a hydralic cylinder. A solid piece of steel that is either welded to the end of the 2x4 tubing, or through it. Then a matching bushing that goes through the 1/2 inch steel plate that attaches it to the FEL.
I'm doing something wrong, because I'm sure the parts must exist online someplace, but so far, I haven't found them. Does anybody know a source that has somethng like this?
I'm also open to any and all suggestions on another way to create a rock solid pivot point for my grapple that doesn't involve me having to machine it myself. Cutting and welding is about the limits of my fabrication skills.
Thank you,
Eddie
Techincal data.
The space between the half inch plates is three inches.
The 2x4 steel tubing is the actuall ouside measurements.
I have one inch bolts, which are working fin, but would prefer to have pins that I don't have to use massive wrenches to take on and off.
I'd like to be able to grease it, but can drill and tap for zirk fittings pretty easily myself.
Thank you,
Eddie
   / Pin and Bushing help needed #3
I purchased some 1.5"OD 1/4" wall steel tubing to use as bushings. Cut a length of tubing 2-3 inches long. Drill a 1.5" hold in your steel. Slide the tubing into the hole, so the hole is centered on the tubing. Weld it in place. Now use a 1" pin to pivot on.
This will give you a greater surface area around the pin and the welds will limit lateral movement. For even better performance, drill a hole in the pin or bushing and install a zerk fitting so you can grease it.
Keep in mind that the power of your cylinder is probably much greater than the strength of the design with 1/2" material. If you pinch down hard enough, you will bend 1/2" steel, assuming it is mild steel. Use the bushings and a light hand on the hydraulic valve and you should have a winning combination.
Marcus
   / Pin and Bushing help needed #4
Eddie, if you want to buy off the shelf stuff, McMaster Carr is the place.
McMaster-Carr
Type in Bushing, or sleeve bearing and start from there. Not sure how to link the webpage after I drilled down, but sure you will find it from there.
Most machine shops keep "bushing stock" on hand.
As much as you do, I am sure there is a machine shop you work with, give them the dimensions and they can knock you out some quick (and my experience is) and reasonable to exact dimensions. The thing I do with the shop that does stuff for me, is to specify how quick I need it, and that greatly effects my prices. It also helps that my wife helped the owner resolve several pond problems he had :)
When I drop a backhoe bucket off to have the bushings bored, and needed it the next day, it was one price, when I had some peices made I was getting for some future work, and he put his guys on it when they were caught up, it was a bit cheaper. But we have a great relationship developed over a couple of years.
Anyway, I think what you are wanting are sometimes called weld in button bushings, They are pretty common and if you look at your buckets etc. you will see them welded in.
Good luck
   / Pin and Bushing help needed #5
Yep- what Marcus said. Around here metal/welding shops sell it as "dimensional tubing" and its sold by the foot.
Its not cheap- around $15 a foot depending on the diameter. They sell it by ID as well.
   / Pin and Bushing help needed #6
Eddie:
What Marcus describes is DOM (drawn over mandrell) tubing. You
can get this from some steel dealers or mail order from Metco Supply.
There are other TBN threads that deal with this issue. Some TBNers
say you can get this bushing stock from some tractor dealers, but
that has not been the case here.
If you are going to use this bushing stock to fully pass thru your
rectangular tubing, it will make a great pivot. What you then need to
find and buy is some 25mm or 63/64" rod for pins. I had much less
prob finding that vs. the DOM tubing. No lathe work will be reqd.
BTW, I have used lots of this stuff for pivots, esp in my CADDigger
project.
   / Pin and Bushing help needed #7
dfkrug makes an excellent point on the 63/64 rod as pins. The tubing is exactly a 1" inner diameter, and the pins that I use are 1" pins. This combination requires that I slightly hone out the tubing.
Marcsu
Thank you everyone. You've given me some new words to use in my searches. I have a pretty good steel shop here in Tyler, and a machine shop that's very reliable, very good and very pricey. hahaha
Eddie
   / Pin and Bushing help needed #9
Yeah, that is too true. The DOM and 1" pins I made were negative clearance. Not having any machine tools, having v large parts that weighed 500 to 1000# and being a cheap sob - I used the old bolt and sand paper method.
Get a 5/8" bolt that is longer than the bushing by about 2-3". Do the Marie Antoinette (cut off the head), and use a sawzall to cut a verticle slit down the length of the bolt about 2 1/4" deep. Put long board sand paper into the slot and wrap it tight. Power it with a drill and you have a hone.
Not pretty, but it does work
jb
   / Pin and Bushing help needed #10
I like your idea. Can you explain "long board" sandpaper? I am not familiar with the term.
thanks,
Marcus
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
LMC LOT NUMBER 144 (A53084)
LMC LOT NUMBER 144...
MALONE 3000TP LOT NUMBER 229 (A53084)
MALONE 3000TP LOT...
2008 JOHN DEERE 270D LC EXCAVATOR (A51246)
2008 JOHN DEERE...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
