Ballast Pie wheel weights
   / Pie wheel weights #1
Loadstar
Platinum Member
Evansville, IN
Ford 640
Recently came across full set of ford pie weights. They were $400 dollars had both plates, all the weights, and all hardware. Are there a lot of different varieties? If so what dimensions am I looking for, for a 600? I have a feeling I should impulse buy these as they look good and are complete. I think one day I would like to add a 900 series to my collection so maybe they would fit one of those.
   / Pie wheel weights #2
I've been looking at them too. That sounds like a deal. I see them on ebay for around $900. From what I have seen there are 2 different weights available 800 or so pounds and 1200 pounds total.
   / Pie wheel weights #3
Sounds like a good deal to me. I believe there are two different weight pies - 35# and 45#. I sold my weights (see my avatar) for $350, but I was missing 2 per side. Each pie weighed 45# and each plate weighed 75#. Some people say the 45#'s are too heavy for the N, but you couldn't prove that by me. Your 600 should have no problems with the 45#.
When you say they come with *all* the hardware, I hope that includes the wheel studs too, because they sell for about $11 each. Also, be sure to check all the threads in those plates.
   / Pie wheel weights #4
Buy the set now. The price is very good if the set is complete. The going rate for a complete set is around $650 in my area.
That said, there are various designs. Without relating all details, the major distinction is the so-called "light" (approximately 30 Lbs./segment) and the so-called "heavy" (approximately 45 Lbs./segment) designs. The "light" design is recommended for use with 6/7xx tractors. Ford did not recommend use of the so-called "heavy" design on 6/7xx tractors but one could, of course, mount every other segment.
Be advised that the so-called "heavy" AG style design interferes with the rails on Ford OEM power adjust rims preventing adjustment of the rims fully outward. There is no interference with the so-called "light" AG style weights or the the so-called "industrial" designs, whether "light" or "heavy." There are no interference issues with six loop rims.
SDT
   / Pie wheel weights
I'm starting to think I should jump on this LOL
   / Pie wheel weights #6
When a good deal comes along, they don't usually last. I'd be surprised if they are still available. :eek:
   / Pie wheel weights
No it's okay. You see I have had my toes crossed since I laid eyes them so I know they are still there waiting for me :D LOL Hope they wait for me till the weekend... toes are tired
2003 Hummer H2 4x4 SUV (A56859)
2003 Hummer H2 4x4...
2025 BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
2025 SDLANCH SDLE20 MINI EXCAVATOR (A58214)
2025 SDLANCH...
2014 Ford Fusion SE Sedan (A55758)
2014 Ford Fusion...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
1998 FREIGHTLINER FL50 SPORT CHASSIS (A56129)
1998 FREIGHTLINER...
