pictures
   / pictures #1
treeman40
lets get some good equitment and mulcher action shots.this site needs some action
   / pictures #2
OK, How about a chain link fence wrapped around the drum? It was laying flat deep in the brush and unavoidable. It jammed into the cutter blade, I needed to flip mulcher over to get everything out. No damage, just cost me a whole day.
   / pictures #3
How did you take a picture of my machine without me knowing? :)
That's a frequent site for me. Also find a lot of old mattress box springs. Barbed wire or electric fence wire is the worst. It wraps so tight you can't get wire cutters between it and the drum (for those of us with smooth drums)
I've been able to get a lot of stuff out by rolling the cutter backwards on the ground. Get a loose end, then run over it with the track, drive forward and it will often pull it off. SOmetimes you have to repeat several times, but it's better that spending hours cutting.
   / pictures #4
I've been able to get a lot of stuff out by rolling the cutter backwards on the ground. Get a loose end, then run over it with the track, drive forward and it will often pull it off. Sometimes you have to repeat several times, but it's better that spending hours cutting.
A trick I use if it's to tight to roll like that is to rap a chain around the rotor 2 or 3times with a hook onto a tooth,tie the other to a tree and quietly drive back,saves a s##t load of blood:D
   / pictures #6
Here's a few pics for ya all. I'll post some more when I get back to Alberta back to my other lap top. Here's a pic of the newest toy.
   / pictures #7
Hey you missed a few.......
   / pictures #8
Nope first pass, had to make two but you cant do it all at once the slope is too steep. Pictures don't do the slopes justice. They are steep very steep. The Lamtrac just crawls up it. Its comical it looks like a caterpillar crawling up the slope, dual articulation. Goes through lots man.
   / pictures #9
Here's a few of the Barko in action...:thumbsup:
   / pictures #10
A few pics from a few of jobs this summer
A couple of "oh crapp"
A couple of new toys.
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
2025 JMR 36in Bucket Skid Steer Attachment (A51691)
2025 JMR 36in...
CHAMPION 7500 WATT GAS GENERATOR (A51248)
CHAMPION 7500 WATT...
2015 Ford Expedition (A51694)
2015 Ford...
UNUSED HURRICANE F10 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
