PICTURES ONLY thread
/ PICTURES ONLY thread #41
Do they have to be tractor pics???
Very nice cut from that flail mower Joe-----wondering how those compare to rotary cutters/bush hogs in terms of finish? Never seen one used in my neck of the woods-----Southern IL
Flail mowers usually do leave a better finish. Most Interstate mowers are flail mowers if I am not mistaken....
Hers is my $200 flail mower :)
I could use one of those... can they plant ANY seed or is it specifically sized for certain kinds?
'Plate' planters work really good for beans and corn. Some of the odder shape seed like pumpkin is harder to get to work. For that, we just take the seed pot off, and put a rider on, and give them a funnel. Said rider is to drop a seed every 'so many' feet.....
I just picked up a 4 row IH-56 planter. We put in 4 rows of corn last weekend with it, (2 at a time). I have ordered more seed plates for it, to handle some of the other size corn seed. I think we shall be doing the same thing for pumpkins still though - we dont put in 'that' many pumpkins, but it sure is nice to have the planter opening up the spot for the seed, and adding the fertilizer.
/ PICTURES ONLY thread #42
B
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=320909"/>
[/QUOTE]
I think it gives a slightly better cut than a bush hog. My flail is considered a rough cut model as it only has 56 knives as opposed to the finish cut model which has 88 knives. Never used a bush hog so I can't give an accurate comparison. The flail works fine for my needs.
Sent from my iPad using TractorByNet
/ PICTURES ONLY thread #44
View from the seat rolling up a bonfire..
/ PICTURES ONLY thread #45
Mama always said there would be days like this.....
/ PICTURES ONLY thread #47
Clearing underbrush with the ratchet rake.
/ PICTURES ONLY thread #48
So I'm thinking about upgrading...
Scary awesome!!!!!
/ PICTURES ONLY thread #49
This is a picture of the lime that I spread for my pole building
If I ever open my hood and have to unlatch the brush guard up front, I always place something over the control so I won't forget to double check that I secured the brush guard.
This is a picture of my Auger with 18" bit.
/ PICTURES ONLY thread #50
Some of yestardays adventures....
Towing the 12' Case Disc...
And one of the several times I found a soft spot (too much **** rain....) and was 'pawing' my way out with the bucket
/ PICTURES ONLY thread #51
Some more....
Here is a shot where I got stuck with both the 12' disc, and the little 5'. I was able to work myself out of both with the bucket, leaving the discs behind. Came back in from the 'dry' side, and pulled them back out with a chain. Was desperately trying to break the ground up some, to get it to dry out. Too bad its RAINING again today!!
Another couple shots discing with the 12'
And... last but not least - getting the planter ready to toss some Sweet Corn in...
/ PICTURES ONLY thread #52
Couple of pictures of starting this years pasture mowing. Very pleased with the new tractor and cutter.
Received 4 gravel trucks of asphalt millings to put on my driveway. It's kinda neat to say my driveway is made out of "Rochester Rd"... A well known and traveled roadway here on the north side of Detroit.
/ PICTURES ONLY thread #54
Well I finally got my grapple on and plumbed. It took me for ever because I just couldn't get the hydraulic fittings terminology down so I kept getting the wrong stuff. Well that just means that I have a few extra parts for the next project.
taking the first bite
Got a pretty good one for my first try.
This is my first attempt at posting pictures I hope it works. I have to make a bracket still to mount the flat face connectors to but I just couldn't wait to go out and try it out. And by doing that I found a problem. I used the switch I installed on the joystick to control the diverter valve direct and took the switch out already so I have to mount a relay and control it with the switch instead, I should have known this but I got in a hurry. I will post more pictures as I get the bugs worked out that is if these even work.
/ PICTURES ONLY thread #55
Yet another use for the bucket mounted hitch.... Keeping centered up on the row marker from the planter!
Rows of pumpkins & squash....
Dad riding the planter - and dropping in squash seeds (hard to get the right seed plate for them)
Rows of corn planted last weekend
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=324292"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=324293"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=324294"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=324295"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=324296"/>
Very cool. What kind of spacing are you doing on the pumpkins? I don't have any planting equipment yet, so I did it the redneck way and made some for rows with a middle buster, dropped the seeds in every few feet, then covered them back up. Actually, I had to do that with the corn and the watermelon too. The pumpkin seedlings are actually coming up pretty well, but I'm sure they would have done better had I had the proper equipment.
So now I have more equipment added to my list of things to buy, which now includes a stump grinder, a grapple, a disc, a cultipacker, and now a planter. ( I know there's more on the list, but I can't remember at the moment).
Moving the wood chipper around...
My poor man garden rows
/ PICTURES ONLY thread #57
The rows themselves are about 11' apart. We did 1 row at a time, using the outer section. Then followed the marker for the next row. Planter is set for 34" rows.... I think it will work quite nice.
Not sure how often he was dropping seeds in... We took the seed pot off, and put a funnel in its place. The rider just drops a seed every 8-10' I think (who knows, he could have been doing them every 4')
We put beans in with it today too. Those, we used the same plates that we used for the silver queen corn.
We have also used this planter to mark rows for transplanting purposes etc.
Here is a pic of the planter when I went to pick it up. Got it for $500 - its an IH-56 4 row. Seems to work decent. Original plan was to make 2 2-row planters out of it, but now I am thinking we may just leave it alone.
This shot is from last weekend, putting sweet corn in - my uncle is making sure the seeds are properly distributed in the pot. Because we plant so little, you have to make sure the seed gets put in the right areas, to work properly with the plate in the planter.
/ PICTURES ONLY thread #58
You should try to buy the Airsteam in the pic behind the planter.They are bringin' good money right now. I'm just sayin':)
Party foul on you! This thread requires a picture be posted with everything response.
/ PICTURES ONLY thread #60
100 hours yesterday....only 6 months, and I was out of town for over a month.
Craftsman 16in Variable Speed Scroll Saw (A64553)
Craftsman 16in...
2025 iRanch IRTPL 10,000lbs. Two Post Automotive Lift (A64194)
2025 iRanch IRTPL...
Lot of 2 ForeRunner 12-16.5N.H.S. Skid Steer Wheels and Tires (A64553)
Lot of 2...
2018 JOHN DEERE 844K-III AG HANDLER WHEEL LOADER (A65053)
2018 JOHN DEERE...
2019 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A64556)
2019 Peterbilt 579...
WEATHERHEAD COLL-O-CRIMP T450-1 HOSE CRIMPER (A64276)
WEATHERHEAD...
