Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #3,211
Got some snow in NH today. Here is my Kubota L2501 with Land Pride SB1064 snowblower and ratchet rake "snow edge" on the bucket. The snow edge works great on the paved portion of the driveway. Use the snowblower on the long gravel part. Works great!
View attachment 491915View attachment 491916
Good looking set up, looks a bit chilly lol
What's the edge on your bucket?
   / Pictures of your snow weapons #3,212
It is the "snow edge" from ratchet rake. Purchased it right here in the TBN forum shop last week.
Snow Edge
   / Pictures of your snow weapons #3,213
If it is of any help, here are a couple pictures of my chain mounting. Previously I have done the drive over method, but I've found
A. These 2 ladder chains of this size are really heavy for this old man
B. Having a free wheeling wheel allows for easier handling and adjusting.
Thus I use a floor jack that has a flat square rubber head about 5 x 5 inches. It fits perfectly under the rear end housing where the draw bar is welded on. Both rear wheels are off the ground and the HST is in neutral with the front wheels blocked.
The hardest part for me is getting the chain cam as tight as I like it....even though I use tensioners.
View attachment 491894View attachment 491896View attachment 491898
I do like your expensive tool for getting the cam lock tight. :D:laughing::thumbsup: Mind if I barrow that idea? It is a tire wrench that the pipe wrench is attached to - correct?
   / Pictures of your snow weapons #3,214
Yeah, Powerscol........Since I save everything.......:eek:.......That old tire wrench I had filed the tip square so it fit in the cam lock. And being an old guy, I didn't have enough umph to turn the handle...........thus the pipe wrench. Have at it.
Edit.......How about Pedzola's rig......Nice looking, but I'll bet he wishes he had a cab if the snow is that often, especially in a windy storm. And I have a question about those rear snow blowers that everybody probably knows the answer......Don't you have to drive that rig backwards to use it??? Some u-tube probably shows one in action.
   / Pictures of your snow weapons #3,215
Very nice package. I,ve got the BX2370 as well, same cab and B2370 blower, and it works awesome.
I,ve got the hydraulic shoot rotation, and just a couple of weeks ago I added the electric actuator to control the shoot deflection. It comes in handy when the snow is light and fluffy, and the wind is constantly changing direction.
The only thing I,m missing is the two lites you have mounted on the front of your cab.
How do you like the illumination they provide ? Can you please provide a link to what they are including part numbers.
I love being able to go out and play in the snow with this set-up.
:thumbsup:
Mounted my new BX5450 onto the Tractor today. I opted for the factory hydraulic chute rotation, I've been reading this thread for 2 years and you guys have some great ideas for chute rotation, but in the end it was just SO easy to throw money at the problem and move on! It's also is under warranty through Kubota.
I had a Rear Mount Blower, but I want to go FORWARD!!
If it NEVER snows again, I'll be happy!
Cheers,
BN
   / Pictures of your snow weapons #3,216
Weve now had 7-8" of snow, but brutal cold weather. This morning it was -6.8F.....not counting wind chill. Warmed up to......... 8F.
Now its 1
Burrrr
   / Pictures of your snow weapons #3,217
   / Pictures of your snow weapons #3,218
After 3 years without snow we finally had a couple of (laughable) "measurable events"
Here's my two loaders back from a 1 AM job clearing emergency access lanes for a large seniors' complex (and more importantly) the parking lot of our neighbourhood pub)
Terry
Those two look like they could move some white stuff! What is the advantage of a center lift arm versus two?
   / Pictures of your snow weapons #3,219
that looks heavy on the front end sticking out that far. How does it work?
I don't need down pressure! Lol. It's not too bad but glad I have one of the dense fluid and weights on the rears.
   / Pictures of your snow weapons #3,220
Generally speaking, tool carriers (single boom) provide level bucket lifting from ground to full height and increased visibility. They almost all come exclusively with quick attach.
Z bar linkage (as equipped on the PINK loader) provide more breakout force and usually quicker loader cycle times.
Both machines pictured are equipped with hydraulic quick attach.
Terry
1999 Ford RV , VIN # 3FCMF53S2XJA29020 (A51572)
1999 Ford RV , VIN...
2011 TROXELL 130BBL (A52472)
2011 TROXELL...
2022 CASE 580 SUPER N BACKHOE (A51246)
2022 CASE 580...
Tradewinds Power Unit (A50120)
Tradewinds Power...
2019 Nissan Versa Sedan (A50324)
2019 Nissan Versa...
