Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #3,081
My Kubota L4850DT-W with 7' McKee blower. I got this in the summer of 2014 and we have had almost no snow since. Last winter I built the cab.
Details on that here ----> http://www.tractorbynet.com/forums/...-diy-cab-build-kubota-l4850dt.html?highlight=
I (kind of) hope we get some real snow this winter.
Wow !!!! I just read your whole cab-build thread and I am completely impressed. It's especially meaningful to me because I looked for a cab a long time too. I've had L4150 and 2 L5450's, all have the same L3 chassis as your L4850. I went the golf cart tent route for a couple seasons and then luckily found a used L5450 for sale with a Laurin cab already installed. I bought it and sold my open-station tractor.
The overall execution of your cab is very impressive. There is a ton of design and fitment work required getting to the high level of your finished product. At the time I was looking the Laurin factory still had a new comfort cab in inventory which with shipment and installation would have been around $14k. That sounds steep until one considers all the detail there is to it, (doors, heat, wipers, lights, etc) Theirs also has an integrated ROPs.
Again, great job - hats off !!
Take care, Dick B.
   / Pictures of your snow weapons #3,082
The wing plow has a telescoping push-arm that pins to the tractor drawbar.
You should post those videos you made a year or so back...
I've seen 'em...in fact, I downloaded them...always fun to watch!
   / Pictures of your snow weapons #3,083
Rear blade vs snowblade?
   / Pictures of your snow weapons #3,084
Take care, Dick B.
Dick,
Thanks for the compliments.
I was a lurker here long before I ever signed up. When the L4850DT came up for sale I started doing lots of research. Your glowing reviews of the Lxx50 series convinced me that I would like the tractor. I really liked it at first, but with the cab it is even better.
My cab clears the ROPS, so the ROPS is fully functional.
Rob
   / Pictures of your snow weapons #3,085
Hi Rob - yes, I know you were able to design around the original ROPS. Part of the Laurin's big price was they designed the whole cab for roll-over strength - they made it so stiff and heavy it even needed stronger frame posts from the rear axle up to the fenders. I swapped my backhoe subframe over to the cab tractor, which added several hundred pounds down low, helping to counter the effect of the Laurin's high-located mass. I think yours has a cleaner look and has the advantage of keeping the center of gravity lower.
I take off the doors and rear window for mowing and I prefer removing the loader too. The valve is now located on the cab, with couplers on the 4 hoses that connect to either loader or blower. Dick B
   / Pictures of your snow weapons #3,086
Thanks Roy.
Will post.. hope to get some new ones this year with my son's GoPro (if we get enough snow to use the wing). Only had it on for a one-time use last winter. Takes about 5 minutes to roll it out and hook it up.
Deere 43 Wing plow - YouTube
   / Pictures of your snow weapons #3,087
Here is my weapon. Works great.
   / Pictures of your snow weapons #3,089
Bl2664 60" , I think, kubota snowblower vs Lucknow 72 inches? Same price and usage. Opinions?
   / Pictures of your snow weapons #3,090
Today I got the dirt weapon uninstalled
Then I had a naked little tractor for a couple of hours
And finally I got the new snow weapon attached . Pretty pumped for some snow :D
Taking the backhoe off for the first time went fairly well . Hopefully getting it back on will go smooth as well !
2018 Nissan Versa Sedan (A50324)
2018 Nissan Versa...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
2014 DITCH WITCH RT45 RIDE ON TRENCHER (A51246)
2014 DITCH WITCH...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
434668 (A51572)
434668 (A51572)
2005 Sterling Acterra Tender Truck (A52748)
2005 Sterling...
