Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #2,351
This is what i use multipurpose.
That doesn't look like a B Series. Might be a C or a D Series. Either way, it's to nice to see a North American product back in the compact lineup.
   / Pictures of your snow weapons #2,352
Looks very expensive, although fun . Probably be cheaper to buy another tractor. ��
Ya probably a new JD 150 hp for the price of what she would cost! 25 years ago my old neighbor 70 year old man told me that a women cost at least 1000 bucks per pound. So with inflation it must be like 1750$ per pound now so lets say 125lbs x 1750$ =218750$ now that would be some nice tractor!!!!
   / Pictures of your snow weapons #2,353
This is the larger half of my setup. Recently got a 90's Arien's ST1032 walk behind to augment. Should make doing the sidewalks and rear deck easier. Speaking of which I need to build a ramp to get the blower up on the deck LOL. This is a 1979 Simplicity 9523 / Allis Chalmers 5020 Hinemoto manufactured tractor. 23 PTO HP 540 PTO speed 2wd Manual tranny. I fabricated the mount for the Meyers plow. You can see my stabilizer bar which runs underneath. It goes from the front plow mount back to the rear trailer hitch assembly to stiffen everything up. May be overkill but better safe than sorry! This way when I plow snow the plow mount is reinforced right back to the rear of the tractor. fwiw The snowblower is an Inland brand which I had to modify quite a lot to get it work effectively. Didn't throw far enough. It's still challenged but much improved. We have certainly had our share of snow here this year. 8ft + within the last couple of weeks. Unfortunately, the implements got buried in the collapsed shelter so I had to dig out of all that with the Arien's. Now that is apart for modifications and bearing/belt replacements. We did have 10" of powder snow last night and this setup worked a treat today. Enjoy. P1030465.jpgP1030463.jpgP1030462.jpgP1030469.JPGP1030467.JPG
   / Pictures of your snow weapons #2,354
Picked up a piece of conveyor belt 4 feet wide and 5 feet long and 3/4" thick. Cut one foot off and bolted to back blade to make a snow plow. Should be good for a few snow storms. DSCN8306.jpg
   / Pictures of your snow weapons #2,355
Picked up a piece of conveyor belt 4 feet wide and 5 feet long and 3/4" thick. Cut one foot off and bolted to back blade to make a snow plow. Should be good for a few snow storms. View attachment 402312
Great idea! Were you running into issues tearing up the ground with the regular back blade?
My driveway is in really bad shape (paved but all cracking and coming apart, needs to be redone) and when I lower my heavy rear blade on it I tend to rip up a lot of "chunks" in the driveway. Something like this would probably help.
   / Pictures of your snow weapons #2,356
Where is "here" at? Help if you'd put your location in your bio. Then we'd know about where 8' of snow fell.
And what are the side wings on the front plow? Look like something to keep snow from filling in behind the blade. ?? Or do they fold out?
   / Pictures of your snow weapons #2,357
Ready to rock 'n roll! :)
I bought this snowblower last June as a demo model. When I went to Oslo area to pick it up I saw it was brand new. Not to bad... After some minor adjustment it fits the front hook-up.
There is no electric chute adjustment on the snowblower but if I will miss this it won't be to difficult to add it i guess.
Regards!
Edward
Let us know if the Hydraulics on the 3030 is enough to run that Blower. I thought most Ag tractors with Aux hydraulics did not provide enough umph to run a Blower.
   / Pictures of your snow weapons #2,358
thats a front pto blower. the hyd is for chute rotate only . should run fine
   / Pictures of your snow weapons #2,359
I agree with you grsthegreat. I have the front mounted snow blower on CK 30. The hydraulics are controlled by my joystick raises/lowers blower and rotates right/left shute. Blower runs of mid PTO. Now if the blower was attached to FEL arms then a bigger hyd pump would be needed or an extra reservoir just to run the blower. Isn't the 3030 a Kubota 30 HP?
2014 Ford F-150 Pickup Truck, VIN # 1FTFW1CT4EKG42947 (A51572)
2014 Ford F-150...
2012 GOOSENECK TRAILER MFG.,CO, INC TANDEM AXLE MANIFOLD TRAILER (A52472)
2012 GOOSENECK...
2007 International 7400 Chassis Truck, VIN # 1HTWGAAR87J437650 (A51572)
2007 International...
2017 Dodge Grand Caravan SE Van (A50324)
2017 Dodge Grand...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A52748)
PENDING SELLER...
