Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #1,612
Karl,
Do you have the Shoule blower on the 5105 or the 4720? What size is it?
   / Pictures of your snow weapons #1,613
Here's a vid from inside. I know it's not very exciting, but this is my first attempts at video.... I'm excited about it. LOL
V8 TJ Plowing - YouTube
Mostly the cul-de-sac and 1st corner of my driveway. When it's heavy or alot I push half of that straight stretch to either end because I have little maple trees on both side and I'm affraid to break them if I just angle the blade
   / Pictures of your snow weapons #1,615
IMG_1646.JPGMy new 2720 with home made cab from the 2320. Frontier blower.IMG_1645.jpg
   / Pictures of your snow weapons #1,616
So I finally got to use the JCB to clear our campus. For scale. The bAy door is 20' high
   / Pictures of your snow weapons #1,617
Ok this seems odd,but the snow isn't coming out of the chute on that big blower...?
Sent from my iPad using TractorByNet
I was thinking the same thing but after looking at the photos and a little research it's quite likely that particular blower has a direct ejection chute option which can bypass the "casting" chute for greater throw distance I presume. These types of chutes can be found on Zaugg self contained 325hp blowers which the loader in, at least, two of the pics appears to have or something similar.
   / Pictures of your snow weapons #1,619
Today... well, before the winch **** a solenoid. LOL
Plowing 3 - YouTube
Obviously you need either studs in those tires or a set of ice chains and they should be loaded with rimguard or Cal. Cloride. Naw on second thought if you loaded those fat boys you either wouldn't have enough engine to turn them or you would twist off drive line components that weren't up to the job. :devil:
2' Auger Extension (A50774)
2' Auger Extension...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
2021 Ford F-150 XL (A50120)
2021 Ford F-150 XL...
2018 KENWORTH T680 SLEEPER TRUCK (A52141)
2018 KENWORTH T680...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2020 Chevrolet Express (A50120)
2020 Chevrolet...
