Pictures of Glow Plugs Installed on PT 1850
   / Pictures of Glow Plugs Installed on PT 1850 #2
ksimolo said:
It can get reasonably cold here (-20ー F) so I decided to install the Deutz glow plugs. Here is a link to a page with some pictures of the glow plugs lit up.
USA Discount Generators - Standby and Portable Gillette Generators
Ken
Cool! My 1845 will start (with lots of cranking) as low as 0 degrees but it sure would be easier on the starter to have a couple of those glow plugs installed. Even one would help. It hadn't occurred to me how easy an upgrade this is :) Thanks for the cool pictures.
Sedgewood
   / Pictures of Glow Plugs Installed on PT 1850 #3
That is way to easy! So how are you wiring it up to the dash? Into the key switch or something else?
I will post a picture of the switch setup soon. I just got in from the barn - was doing the final wiring on the tractor. Now I have my new front lights wired, a switch for the glow plugs, a switch for future rear/interior lights, and finally a switch for the flashing light (very irritating at night in the middle of nowhere but very useful when on the road). Everything but the flashing light is run off relays controlled by the key switch. I am using the existing circuit for the flashing light - this circuit is hooked directly to the key switch. Also got my Miny Tach wired up - thanks Carl for that one!!! Now I have to put all the covers back on, pick up the tools and use the PT to move some heavy stuff around this afternoon. My PT has been down for 2 weeks while doing all this so it will be nice to be able to use it again. There are lots of tall weeds that need chopping.
Ken
LOT: Coolant Pressure Tester, Fuel Pressure Tester, Amp Tester (A59076)
LOT: Coolant...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2012 MACK GU713 (A58214)
2012 MACK GU713...
2012 FORD F-550 SUPER DUTY CAB AND CHASSIS (A58214)
2012 FORD F-550...
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
