Pictures of carryall weld up kit by redlandhill.com
   / Pictures of carryall weld up kit by redlandhill.com #1
kvjohndeere
Chesterfield,Va.
JohnDeere 2305 / 4310
http://[IMGhttp://i182.photobucket.com/albums/x247/kvjohndeere/100_0779.jpg[/IMG]
   / Pictures of carryall weld up kit by redlandhill.com #2
So carry all is compatable with I-match?
I bought The Kit From 3 POINT HITCH WELD UP CARRY-ALL KIT & I told Bill The owners The dimensions for My Imatch Quickhitch & Did some modifying Myself to make it Work ! Plus A little John Deere Paint & my welding machine !
   / Pictures of carryall weld up kit by redlandhill.com #4
Nice job ... Are you going to leave it the way it is to use the forks, or cover it with plywood?
I got going to use it both ways Im going to build an oak & walnut platform for it & connect it with square D tractor pins 3/8" instead of bolts ! The forks are great also ! for pallats to move any heavy objects ! ! Man This Thing is awesome just Talk To Bill At 3 POINT HITCH WELD UP CARRY-ALL KIT He will Fabricate it the way you want ! He uses 2-1/2" x1/4" Angle Heavy duty ! Take it easy BX24
   / Pictures of carryall weld up kit by redlandhill.com #6
what would you use the upper pins for? I was thinking of one of these for a pto generator carryall if I ever get the generator. the generator company sells a carrier for $200. + a little expensive.
   / Pictures of carryall weld up kit by redlandhill.com #7
What is that lever on the left top? Looks like a crank? (never mind - I guess that is part of the Imatch)
I think it would be real handy to have a box to go on it too, in addition to just a platform. I alread have pallet forks for the loader, so I would probably just leave the box on. Maybe it could be done like a flatbed truck with removable sides.
They came with the kit I guess If didnt want to use the The Imatch you could different heights ! redlandhill sells the the kit for 75.00 not bad !It would be great for a generator !
That sounds like A great Idea !
2013 Chevrolet Caprice Sedan (A55758)
2013 Chevrolet...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2007 DRAGON 150...
2016 Ford Fusion Hybrid Sedan (A55758)
2016 Ford Fusion...
2008 Ford F-450 Chassis Truck, VIN # 1FDXW46R48EC52709 (A54865)
2008 Ford F-450...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2011 Chevrolet Traverse 1LT SUV (A53424)
2011 Chevrolet...
