Pictures of carryall weld up kit by redlandhill.com
   / Pictures of carryall weld up kit by redlandhill.com #1
kvjohndeere
Chesterfield,Va.
JohnDeere 2305 / 4310
http://[IMGhttp://i182.photobucket.com/albums/x247/kvjohndeere/100_0779.jpg[/IMG]
   / Pictures of carryall weld up kit by redlandhill.com #2
So carry all is compatable with I-match?
I bought The Kit From 3 POINT HITCH WELD UP CARRY-ALL KIT & I told Bill The owners The dimensions for My Imatch Quickhitch & Did some modifying Myself to make it Work ! Plus A little John Deere Paint & my welding machine !
   / Pictures of carryall weld up kit by redlandhill.com #4
Nice job ... Are you going to leave it the way it is to use the forks, or cover it with plywood?
I got going to use it both ways Im going to build an oak & walnut platform for it & connect it with square D tractor pins 3/8" instead of bolts ! The forks are great also ! for pallats to move any heavy objects ! ! Man This Thing is awesome just Talk To Bill At 3 POINT HITCH WELD UP CARRY-ALL KIT He will Fabricate it the way you want ! He uses 2-1/2" x1/4" Angle Heavy duty ! Take it easy BX24
   / Pictures of carryall weld up kit by redlandhill.com #6
what would you use the upper pins for? I was thinking of one of these for a pto generator carryall if I ever get the generator. the generator company sells a carrier for $200. + a little expensive.
   / Pictures of carryall weld up kit by redlandhill.com #7
What is that lever on the left top? Looks like a crank? (never mind - I guess that is part of the Imatch)
I think it would be real handy to have a box to go on it too, in addition to just a platform. I alread have pallet forks for the loader, so I would probably just leave the box on. Maybe it could be done like a flatbed truck with removable sides.
They came with the kit I guess If didnt want to use the The Imatch you could different heights ! redlandhill sells the the kit for 75.00 not bad !It would be great for a generator !
That sounds like A great Idea !
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2008 Blue Bird School Bus (RUNS)(TITLE) (A50775)
2008 Blue Bird...
2015 Dodge Grand Caravan (A53424)
2015 Dodge Grand...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55787)
2025 Kivel 48in...
IRGC40 Electric Tricycle (A55758)
IRGC40 Electric...
CFG Industrial MH12RX (A53316)
CFG Industrial...
