pictures of a third function on a grand L please help..
   / pictures of a third function on a grand L please help.. #1
mark2610d
Tennessee
L3240HSTC
I have all the stuff to do a third function EV on my L3240HSTC and I really need someone to post some pictures so I can locate the correct PB line to connect into. It would also be nice to have ideas on mounting locations and quick conect brackets for the loader.
As they say a picture is worth a thousand words...... :)
Any help would be much appreciated,
   / pictures of a third function on a grand L please help.. #2
I don't have a Grand L so I'm not sure where your PB comes from.
Here are some pics of where I mounted the solenoid valve on my Kama. It's located on the left FEL torque tube. There are QD's right there so the hoses can be disconnected when removing the FEL. It's out of the way and protected there. I did the same on my wife's tractor. Find your PB high pressure line and route it to the valve and a return line back into the system.
Rob-
   / pictures of a third function on a grand L please help.. #3
do a search on my posts (SCDolphin) on third function valves..........started with all factory Kubota but their valves leaked down so went with a mix of WRLong valves and kubota controller
   / pictures of a third function on a grand L please help.. #4
Did you get your valve hooked up? I'm looking into doing the same on my 3540
   / pictures of a third function on a grand L please help.. #5
I originally wanted to stay with all kubota but that being said the Kubota diverter valve was a large clunky box just begging to be ripped off. It also leaked so when my 4n1 was open the jaws would leak down. The actual control stick from Kubota is good. The dealer replaced the diverter valve to a WRLong valve which is tucked out of the way. If you can't find my post with pictures let me know
   / pictures of a third function on a grand L please help.. #6
I actually cannot find it with the search. Can you post it if you know where it is? Thanks
   / pictures of a third function on a grand L please help.. #7
I've got a post on here when I bought my millonzi grapple last year, do a asearch for millonzi grapple and you will see. good luck
2016 Great Dane 102"x48' Step Deck (A50123)
2016 Great Dane...
EASTWOOD MIG250 WELDER (A51248)
EASTWOOD MIG250...
(APPROX 24) 2" X 3" X 39" THICK TUBING (A51247)
(APPROX 24) 2" X...
Hydraulic 80 mm pin thumb & coupler combo (A52384)
Hydraulic 80 mm...
UNUSED AGT YSRT14 STAND-ON SKID STEER (A51247)
UNUSED AGT YSRT14...
DELTA TRUCK BED TOOLBOX (A51248)
DELTA TRUCK BED...
