Pictures from an athletic field contractor
   / Pictures from an athletic field contractor #391
Why do you need 12 acres to be so flat? Hay?
Actually, it's not flat. It's graded with a slight slope so that it drains well. This was a rice field back in the 70's. Then soybeans and hay since then. Plowing it in the same direction for many years caused some low areas, especially where the equipment would turn. It was holding water in those areas. Now it should drain quickly.
   / Pictures from an athletic field contractor #393
Is it going to be a hay field again?
   / Pictures from an athletic field contractor #394
Laser grading on a different scale. This is on a 12 acre piece that I own. It would have taken me at least a week to grade this field.
My son in law did it in about 4 hours with his dads equipment
That field is smooth enough now to be sprigged with hay grass in the spring. :D
   / Pictures from an athletic field contractor #395
Looks like a good field, you might even say a Field of Dreams. :)
I'm not sure what we are going to do with this piece of land. All my other land is now in sugar cane. I just wanted this to drain properly. My daughter and son in law might do some organic farming on this piece.
Repairing a broken T in a 3" irrigation line is not one of my favorite jobs, but it's all part of the game.
   / Pictures from an athletic field contractor #400
Oof! You're in 300 - 400 GPM territory, at 3 inch! I can't even imagine the water bill.
Krause Dominator 4850-18ft (A57024)
Krause Dominator...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
Komatsu Midi Excavator (A55851)
Komatsu Midi...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55851)
2025 Kivel 48in...
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
Tradewinds Power Unit (A50120)
Tradewinds Power...
