Pictures from a skid steer mowing contractor
   / Pictures from a skid steer mowing contractor
A picture or two from a couple of different jobs this week, one forestry mowing an overgrown driveway/property line for a new customer and the other was mulching a property line in a really tight place due to customer only wanting vines and small brush removed, it's warming up down here in Florida but nothing like what it will be shortly, hope everyone is having a good week.
   / Pictures from a skid steer mowing contractor #892
How well does your A/C keep up in the heat?
   / Pictures from a skid steer mowing contractor #895
Most of the jobs I get for tractor bush hogging are 10 acres or less and usually have quite a few trees with low hanging branches that I need my small tractor to mow around, I use a 6' mower for those jobs with a 35 hp tractor and can mow all day on less than 10 gallons of diesel. If I get any bigger I am going to have to buy a batwing mower, but I really prefer the skid steer work and I may need to go up on my rates, I am just going to have to sit down and run all the numbers and see , but so far it is working out.
I have a smaller size skid steer.. Its a Cat 246 that I put a set of Logering VTS tracks on.. Basically a entire new undercarriage .. Tires come off and the whole track system is bolted on it their place. I did this when the machine had 400 hours on it and needed its 3rd set of tires. The tracks are now old and cracked so those will be getting replaced soon. The reason I'm telling you all this is the cost involved in operating a skid. When I got mine the Cat dealer estimated it costs 6.00 per hour in maintenance to run a skid. Wear and tear, general maintenance etc. .. Today I would bet its closer to 10.00 per hour..maybe more depending on the machine.
   / Pictures from a skid steer mowing contractor #896
I remember when the CTL were becoming more popular 20 +/-years ago and the stated operation costs (per an equipment trade magazine) was around you $6/hrs for a SS and in the $12/hrs for a CTL.
Now many sites the added flotation is required and let's face it, they're much cooler,😉
But that's something to consider not to mention the addition purchase cost for someone crunching the numbers considering starting a service based on one of these very versatile machines. 👍
   / Pictures from a skid steer mowing contractor #897
In certai, specific operations, tires are better; like milling around radius' with a milling head. Tires really dont have a much down side on asphalt. Don't think anyone still makes something like the Bobcat A300, which had 4 wheel steering.
Besides that, and maybe tree planting for a landscaper, I would hazard 80% of the time tracks are better.
For stuff like landscape supply yards, a compact wheel loader, is better than either...
Mulching, things like gopher turtle holes, hidden bed frames, ect, tracks all the way.
Even with tracks, there are wider, lower ground pressure ones,
Thanks for the tip, mine has continued to be troublefree but I don't slack on maintenance and no telling how many cartridges of grease that I have gone through, I grease non stop, but you are correct when something goes wrong it's probably not going to be cheap to fix.
   / Pictures from a skid steer mowing contractor #899
Sure it probably cost more to maintain a track machine but a track machine will work circles around a wheeled machine. I’m not convinced the cost per job is actually cheaper with wheels. Putting purchase costs aside how much is it worth for this not to happen every time you drive somewhere a little bit soft? I sold that wheeled machine a couple years ago and the only thing I miss is how fast it would drive. The track machine is better in every other aspect.
   / Pictures from a skid steer mowing contractor #900
Sure it probably cost more to maintain a track machine but a track machine will work circles around a wheeled machine. I’m not convinced the cost per job is actually cheaper with wheels. Putting purchase costs aside how much is it worth for this not to happen every time you drive somewhere a little bit soft? I sold that wheeled machine a couple years ago and the only thing I miss is how fast it would drive. The track machine is better in every other aspect. View attachment 3650897
yeah.. I got stuck one too many times with tires in mud. Never even been close to getting stuck with the tracks. But they now need to be replaced .. Im guessing 3K for new ones. Tires would be 600 ish. .. Pay to play. .. I think I got 400 hours out of this set.. They still have tread but the splits in them are pretty bad.
2023 AGT Topcat Stump Grinder (A51573)
2023 AGT Topcat...
2021 Caterpillar 299D3XE Track Loader (A53342)
2021 Caterpillar...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A53472)
2016 Kawasaki 70...
2024 JOHN DEERE 8RX310 LOT NUMBER 77 (A53084)
2024 JOHN DEERE...
2001 International 4700 Dump Truck with Compressor, VIN # 1HTSCAAN91H363922 (A51572)
2001 International...
Husqvarna 120 Chainsaw (A51573)
Husqvarna 120...
